Function "Command" From lisp
16 Posts 6 Posters 1.8k Views 6 Watching
    Matt666
    Hi every body !
    Before using sketchup, which became completely indispensable πŸ˜‰ , I used autocad and its language Lisp. The lisp contains a very interesting feature: the "command" function.
    It allows you to use all tools autocad in the running. All the arguments are replies to messages orders.
    Example : (command "_line" "0,0,0" "10,0,10" "50,50,50")
    And to close the line command : (command "")
    Do you think it would be possible to create a similar function in ruby?
    PS : Sorry for that frenglish !!!
    Frenglish at its best !
    My scripts
      AdamB
      SU has a language built-in for a similar purpose. Its called Ruby.
      At the console you can execute Ruby commands to create geometry etc.
      eg
      Sketchup.active_model.entities.add_line([0,0,0], [3,1,4])
      adds a line to your model.
      Sketchup.active_model.entities.add_text "Allez Les Bleus", [5,6,7]
      adds some "camera-facing" text at coordinates 5,6,7
      etc etc
      http://download.sketchup.com/OnlineDoc/gsu6_ruby/Docs/ruby-classes.html for every function.
      Adam
        Matt666
        Hello AdamB !
        yes, I know these methods.
        "Command" function can use ALL the existing commands... AND also user commands... Very interesting !
        πŸ˜„
        For example How can you add a dimension...
        Thank you for your answer !
        My scripts
          Didier Bur
          Hi Matt,
          Pas possible d'ajouter des cotes (no way to add dimensions).
          Regarde la mΓ©thode send_action pour le peu qu'on peut faire (take a look at send_action method)
          Sketchup.active_model.send_action soccer.delete[Netherlands,Italy,Romania] 🀣
          DB
            Matt666
            Hello Didier !
            Sketchup.send_action 21410
            But I can't control the action process !
            For example, to find the dimension between 2 points given by the program... Not by the user !
            Any idea ? πŸ˜‰
            My scripts
              Didier Bur
              In fact, send_action just performs an action which doesn't need any user input, or selects a tool (afaik).
              If you want to get the distance between 2 points, you don't need dimensions for that (d=p1.distance p2). If you want your script to draw a dimension, I think this is impossible.
              I hope I'm wrong...
              DB
                Matt666
                Grmbl
                Ok ! Thank you Didier !
                My scripts
                  Matt666
                  an "entmake" in lisp ! Ok, thank you ! I will try it, even if I don't know the method !
                  thank you TIG !
                  My scripts
                  • Wo3DanW Offline
                    Wo3Dan
                    @didier bur said:
                    ......Sketchup.active_model.send_action soccer.delete[Netherlands,Italy,Romania] 🀣
                    Hi Didier, is this going to be your next (and shortest) SU ruby plugin to get rid of us before we even started? 😲 πŸ˜• --> 😠
                    πŸ˜‰
                    Wo3Dan
                      @didier bur said:
                      I hope I'm wrong...
                      Getting distances between two points is easy as stated...
                      You CAN'T make dimensions direct from Ruby, BUT you can make a dimension-component.skp (or a set of various ones) that are stored in a Plugins sub-folder - these have a 'base' length, your script then has you pick two points - it places the component at p1 and rotates it to towards p2 and also scales it by the required factor p1_to_p2 : base... Point p3 could be an offset and scale approproiately for this...
                        Matt666
                        Hello !
                        It's strange Ruby can't answer to a Sketchup pending command ! 😞 😲 πŸ˜•
                        I would like to create a tool for continuous dimension. Acad like !
                        1- Draw a simple dimension
                        2- Retrieving the last basis point of the first dimension
                        3- draw a dimension with the first basis point already given.
                        If I understand, we must re-program dimension tool ?? 😲
                        My scripts
                          Matt666
                          Can I do smt with the observer tools ?
                          When a user action is done, the observer returns the action ??? And we just have to send the action to the tool... no ? πŸ˜•
                          My scripts
                            Matt666
                            Sketchup.active_model.send_action coach.delete[Raymond Domenech]...
                            My scripts
                              toxicvoxel
                              The blokes at HQ would make life a lot simpler if they could provide simple GET functions (GETPoint,GetAngle,GetDistance etc.) - quite difficult and probably beyond many to do in Ruby with a tools class. If only they would apply the Sketchup 'simplicity' ethos to the API.
                                Didier Bur
                                I agree 1000%
                                DB
                                  Matt666
                                  +1... 😲 😞
                                  My scripts
