    Function "Command" From lisp
    16 Posts 6 Posters 2.1k Views 6 Watching
      Matt666
      Hi every body !
      Before using sketchup, which became completely indispensable 😉 , I used autocad and its language Lisp. The lisp contains a very interesting feature: the "command" function.
      It allows you to use all tools autocad in the running. All the arguments are replies to messages orders.
      Example : (command "_line" "0,0,0" "10,0,10" "50,50,50")
      And to close the line command : (command "")
      Do you think it would be possible to create a similar function in ruby?
      PS : Sorry for that frenglish !!!
      Frenglish at its best !
      My scripts
      • AdamBA Offline
        AdamB
        SU has a language built-in for a similar purpose. Its called Ruby.
        At the console you can execute Ruby commands to create geometry etc.
        eg
        Sketchup.active_model.entities.add_line([0,0,0], [3,1,4])
        adds a line to your model.
        Sketchup.active_model.entities.add_text "Allez Les Bleus", [5,6,7]
        adds some "camera-facing" text at coordinates 5,6,7
        etc etc
        http://download.sketchup.com/OnlineDoc/gsu6_ruby/Docs/ruby-classes.html for every function.
        Adam
          Matt666
          Hello AdamB !
          yes, I know these methods.
          "Command" function can use ALL the existing commands... AND also user commands... Very interesting !
          For example How can you add a dimension...
          Thank you for your answer !
          My scripts
          • Didier BurD Offline
            Didier Bur
            Hi Matt,
            Pas possible d'ajouter des cotes (no way to add dimensions).
            Regarde la méthode send_action pour le peu qu'on peut faire (take a look at send_action method)
            Sketchup.active_model.send_action soccer.delete[Netherlands,Italy,Romania] 🤣
            DB
              Matt666
              Hello Didier !
              Sketchup.send_action 21410
              But I can't control the action process !
              For example, to find the dimension between 2 points given by the program... Not by the user !
              Any idea ? 😉
              My scripts
                Didier Bur
                In fact, send_action just performs an action which doesn't need any user input, or selects a tool (afaik).
                If you want to get the distance between 2 points, you don't need dimensions for that (d=p1.distance p2). If you want your script to draw a dimension, I think this is impossible.
                I hope I'm wrong...
                DB
                  Matt666
                  Grmbl
                  Ok ! Thank you Didier !
                  My scripts
                    Matt666
                    an "entmake" in lisp ! Ok, thank you ! I will try it, even if I don't know the method !
                    thank you TIG !
                    My scripts
                    • Wo3DanW Offline
                      Wo3Dan
                      @didier bur said:
                      ......Sketchup.active_model.send_action soccer.delete[Netherlands,Italy,Romania] 🤣
                      Hi Didier, is this going to be your next (and shortest) SU ruby plugin to get rid of us before we even started? 😲 😕 --> 😠
                      Wo3Dan
                        @didier bur said:
                        I hope I'm wrong...
                        Getting distances between two points is easy as stated...
                        You CAN'T make dimensions direct from Ruby, BUT you can make a dimension-component.skp (or a set of various ones) that are stored in a Plugins sub-folder - these have a 'base' length, your script then has you pick two points - it places the component at p1 and rotates it to towards p2 and also scales it by the required factor p1_to_p2 : base... Point p3 could be an offset and scale approproiately for this...
                          Matt666
                          Hello !
                          It's strange Ruby can't answer to a Sketchup pending command ! 😞 😲 😕
                          I would like to create a tool for continuous dimension. Acad like !
                          1- Draw a simple dimension
                          2- Retrieving the last basis point of the first dimension
                          3- draw a dimension with the first basis point already given.
                          If I understand, we must re-program dimension tool ?? 😲
                          My scripts
                            Matt666
                            Can I do smt with the observer tools ?
                            When a user action is done, the observer returns the action ??? And we just have to send the action to the tool... no ? 😕
                            My scripts
                              Matt666
                              Sketchup.active_model.send_action coach.delete[Raymond Domenech]...
                              My scripts
                                toxicvoxel
                                The blokes at HQ would make life a lot simpler if they could provide simple GET functions (GETPoint,GetAngle,GetDistance etc.) - quite difficult and probably beyond many to do in Ruby with a tools class. If only they would apply the Sketchup 'simplicity' ethos to the API.
                                  Didier Bur
                                  I agree 1000%
                                  DB
                                    Matt666
                                    +1... 😲 😞
                                    My scripts
