    Function "Command" From lisp
    16 Posts 6 Posters 2.5k Views 6 Watching
    • Didier BurD
      Didier Bur
      In fact, send_action just performs an action which doesn't need any user input, or selects a tool (afaik).
      If you want to get the distance between 2 points, you don't need dimensions for that (d=p1.distance p2). If you want your script to draw a dimension, I think this is impossible.
      I hope I'm wrong...
      DB
        Matt666
        Grmbl
        Ok ! Thank you Didier !
        Frenglish at its best !
        My scripts
          Matt666
          an "entmake" in lisp ! Ok, thank you ! I will try it, even if I don't know the method !
          thank you TIG !
          My scripts
          • Wo3DanW
            Wo3Dan
            @didier bur said:
            ......Sketchup.active_model.send_action soccer.delete[Netherlands,Italy,Romania] 🀣
            Hi Didier, is this going to be your next (and shortest) SU ruby plugin to get rid of us before we even started? 😲 πŸ˜• --> 😠
            πŸ˜‰
            Wo3Dan
              @didier bur said:
              I hope I'm wrong...
              Getting distances between two points is easy as stated...
              You CAN'T make dimensions direct from Ruby, BUT you can make a dimension-component.skp (or a set of various ones) that are stored in a Plugins sub-folder - these have a 'base' length, your script then has you pick two points - it places the component at p1 and rotates it to towards p2 and also scales it by the required factor p1_to_p2 : base... Point p3 could be an offset and scale approproiately for this...
                Matt666
                Hello !
                It's strange Ruby can't answer to a Sketchup pending command ! 😞 😲 πŸ˜•
                I would like to create a tool for continuous dimension. Acad like !
                1- Draw a simple dimension
                2- Retrieving the last basis point of the first dimension
                3- draw a dimension with the first basis point already given.
                If I understand, we must re-program dimension tool ?? 😲
                My scripts
                  Matt666
                  Can I do smt with the observer tools ?
                  When a user action is done, the observer returns the action ??? And we just have to send the action to the tool... no ? πŸ˜•
                  My scripts
                    Matt666
                    Sketchup.active_model.send_action coach.delete[Raymond Domenech]...
                    My scripts
                    • T
                      toxicvoxel
                      The blokes at HQ would make life a lot simpler if they could provide simple GET functions (GETPoint,GetAngle,GetDistance etc.) - quite difficult and probably beyond many to do in Ruby with a tools class. If only they would apply the Sketchup 'simplicity' ethos to the API.
                      • Didier BurD
                        Didier Bur
                        I agree 1000%
                        DB
                          Matt666
                          +1... 😲 😞
                          My scripts
