    [Plugin] Custom Toolbars Plugin
    121 Posts 43 Posters 75.1k Views 43 Watching
      Jim
      To create a custom toolbar, you create a plain text file in the jf_custom_toolbars folder.
      The name of the text file becomes the name of the Toolbar.
      The contents of the text file is a list of commands taken from the commands in the image.
      Look for the "Edge Style Example.txt" file in your Plugins/jf_custom_toolbars folder for an example toolbars.
      http://bp1.blogger.com/_ogonR-k5OoM/SFQzmxh8aeI/AAAAAAAAHXQ/pifUCnbkhf8/s1600/toolbar_commands.jpg
      • ibonI Offline
        ibon
        This is Awesome! keep on with the project, please. Do you need help with the icons? i have changed a little my sketchup, so maybe i could help. Thanks again!
        http://img377.imageshack.us/img377/1050/pantallaum2.th.jpg
        • W Offline
          watkins
          Dear Jim,
          I'm sure that it is obvious to everyone else, but how do you go about installing the scripts. A little explanation of what the plugin does and how one might use it effectively. I am loathe to change what I have without an understanding of the benefits. I know that you are very busy, but if you could write a simple 'how to install and use' document, with perhaps a few examples then, that would be most helpful.
          Many thanks,
          Bob
            Daniel S
            Ibon.. can you share the icons of the bezier tool and the ones for the tools on surfaces (offset and line on surface)? They look really great!!!
            Daniel S
              rsw
              @jim said:
              I've posted a beta release of custom toolbars on my blog (see my sig.)
              thought I would find this quite useful as I tend to use icons rather than shortcuts most of the time, but I can't seem to download it from your blog, I just get to a page which says I don't have permission to view this page - could you post it here on scf instead?
              Richard
                Jim
                I had some security settings set wrong, it should work now. Sorry.
                  Jim, thank you for this. I was able to download it yesterday and I think I installed it correctly--all into the Plugins folder and otherwise the paths shown in the Zip file were left alone. I haven't figured out how to activate the toolbars though. Any ideas of how to teach an idiot how to work this? 😉
                    Jim
                    They should all be under View > Toolbars menu.
                    A toolbar file is just a text file in the Plugins/Toolbars folder. You can see some example in there already.
                      That's kind of what I thought. Maybe I need new glasses.
                        Jim
                        Uh, this is a dumb question, but you did restart SketchUp, right?
                        There should be a toolbars.rb file in Plugins also.
                          Not such a dumb question but yes, I did restart SU several times since installing the files. The computer has even been restarted a couple of times since I installed the files.
                            Jim
                            OK, did you check the Extensions tab of the Preferences dialog?
                            I thought I had done away with the extensions interface, which is why I didn't suggest it first. I can't keep track of my own plugins.
                              Holy buckets! That did it. I don't think I've had to go in and check a box under Extensions since I first loaded the V6 a long time ago. It didn't occur to me that there'd be a new box to check.
                              Thanks Jim. That was the fix.
                                rsw
                                works fine now, thanks
                                Richard
                                  dudekracked
                                  hi jim thanks for this useful plugin 👍
                                  im just wondering if it will be something like the one on your site after you finish it?
                                  i copied the picture on your site, 😳 will it end up something like this? i kinda like this actually, is it possible to do this? thanks
                                  • H Offline
                                    HFM
                                    Eh seriously, it is exactly like that! Every button on that page you can use in a custom toolbar... or create new icons
                                    RTFM or in this case RTFRBFILES that are included 😄
                                    and again Jim thanx for this one [it's keeping me up at night creating icons 😲 ]
                                      dudekracked
                                      @HFM
                                      no, no, no, your not reading me clearly, 👎 i absolutely like the idea of a kind of floating toolbar that has all the tools inside it with the name beside it and if all possible can be customized, exactly like the picture that ive attached earlier.
                                      • I Offline
                                        ilay7k
                                        also need shortcut(command) to hide/show all of them...like at most sculpting tool - for clear sketchup desktop(slide away)
                                        • H Offline
                                          HFM
                                          @dudekracked said:
                                          @HFM
                                          Ooooh,...
                                          Why? If you hover over the icons you get the name too. Anyways, sorry for the misunderstanding.
                                          Hugo
                                            Jim, this is pretty slick. I made a replacement for the Camera toolbar that includes centerSelection. So now there's eight tools in that bar instead of 7. I include the TXT file for anyone who might want to do the same thing.
                                            Zoom1.txt
                                            • 6
                                            • 7
                                            • 1 / 7
