    [Plugin] Custom Toolbars Plugin
    121 Posts 43 Posters 73.1k Views 43 Watching
      Jim
      They should all be under View > Toolbars menu.
      A toolbar file is just a text file in the Plugins/Toolbars folder. You can see some example in there already.
        That's kind of what I thought. Maybe I need new glasses.
          Jim
          Uh, this is a dumb question, but you did restart SketchUp, right?
          There should be a toolbars.rb file in Plugins also.
            Not such a dumb question but yes, I did restart SU several times since installing the files. The computer has even been restarted a couple of times since I installed the files.
              Jim
              OK, did you check the Extensions tab of the Preferences dialog?
              I thought I had done away with the extensions interface, which is why I didn't suggest it first. I can't keep track of my own plugins.
                Holy buckets! That did it. I don't think I've had to go in and check a box under Extensions since I first loaded the V6 a long time ago. It didn't occur to me that there'd be a new box to check.
                Thanks Jim. That was the fix.
                  rsw
                  @jim said:
                  I had some security settings set wrong, it should work now. Sorry.
                  works fine now, thanks
                  Richard
                    dudekracked
                    hi jim thanks for this useful plugin πŸ‘
                    im just wondering if it will be something like the one on your site after you finish it?
                    i copied the picture on your site, 😳 will it end up something like this? i kinda like this actually, is it possible to do this? thanks
                    • H Offline
                      HFM
                      Eh seriously, it is exactly like that! Every button on that page you can use in a custom toolbar... or create new icons
                      RTFM or in this case RTFRBFILES that are included πŸ˜„
                      and again Jim thanx for this one [it's keeping me up at night creating icons 😲 ]
                        dudekracked
                        @HFM
                        no, no, no, your not reading me clearly, πŸ‘Ž i absolutely like the idea of a kind of floating toolbar that has all the tools inside it with the name beside it and if all possible can be customized, exactly like the picture that ive attached earlier.
                        • I Offline
                          ilay7k
                          also need shortcut(command) to hide/show all of them...like at most sculpting tool - for clear sketchup desktop(slide away)
                          • H Offline
                            HFM
                            @dudekracked said:
                            @HFM
                            Ooooh,...
                            Why? If you hover over the icons you get the name too. Anyways, sorry for the misunderstanding.
                            Hugo
                              Jim, this is pretty slick. I made a replacement for the Camera toolbar that includes centerSelection. So now there's eight tools in that bar instead of 7. I include the TXT file for anyone who might want to do the same thing.
                              Zoom1.txt
                              • urgenU Offline
                                urgen
                                ...good idea Jim πŸ‘ thanks! πŸ˜„
                                --pupil forever...------
                                  sky2779
                                  my sketchup is in D:\Program Files\Google\Google SketchUp 6
                                  I did put the toolbars into the plugins folder but nothing happened
                                    Read through the thread.
                                    Go to Preferences and check the appropriate box under Extensions.
                                      Jim
                                      Just curious if anyone discovered the "double" meaning of some of the icons? πŸ˜„
                                      Nathan Cheever (alz) is the one who did all the work and deserves all the kudos for the custom icons. Thanks again, Nathan!
                                        Double meaning? As in the icons for togglePerspective and toggleAxes? πŸ˜‰
                                          ScottPara
                                          Now we just need someone to make buttons for the missing icons!
                                          Great plugin!!!!
                                          Scott
                                          If anyone has created buttons for the missing icons please post them for others who are not as creative
                                          Love the fact that some HATE my avatar.....
                                          • N Offline
                                            Nexus009
                                            Jim, thaaaaaaaanks!!!!!!!!!!! πŸ‘ πŸ˜„
                                            http://files.myopera.com/Nexus009/icon/clapclap.gif
                                            http://files.myopera.com/Nexus009/icon/ok.gif
                                            Il mio Teschio Γ¨ una Bandiera che vuol dire LibertΓ
                                            • 1 / 7
