    Import dashed line
    5 Posts 4 Posters 1.8k Views 4 Watching
      jukkoo
      is it possible to import a dashed or dotted line from autocad into sketchup? (like white lines on the road, if u know what i mean)
      • jujuJ Offline
        juju
        not AFAIK, you'll have to draw them manually again (or use components).
          jukkoo
          thanx fo the reply juju, but what exactly do u mean: use components?
            dylan
            If you created a component from you line segmant, you could then just copy it as many times as you like quite quickly or copy along a path. Drawing a dashed line in SU manually could prove time consuming.
            A lot depends on what you require the line for, such as road markings, or just to show a hidden line etc.
            http://dmdarchitecture.co.uk/
            • Didier BurD Offline
              Didier Bur
              Download dashes.rb here:
              http://www.crai.archi.fr/RubyLibraryDepot/Ruby/em_arc_page.htm
              It may help you.
              DB
