🛣️ Road Profile Builder | Generate roads, curbs and pavements easily  Download
Import dashed line
is it possible to import a dashed or dotted line from autocad into sketchup? (like white lines on the road, if u know what i mean)
not AFAIK, you'll have to draw them manually again (or use components).
thanx fo the reply juju, but what exactly do u mean: use components?
If you created a component from you line segmant, you could then just copy it as many times as you like quite quickly or copy along a path. Drawing a dashed line in SU manually could prove time consuming.
A lot depends on what you require the line for, such as road markings, or just to show a hidden line etc. -
Download dashes.rb here:
http://www.crai.archi.fr/RubyLibraryDepot/Ruby/em_arc_page.htm
It may help you.
