    [Obsolete] Offset On Surface (v1.0)
    48 Posts 34 Posters 28.4k Views 34 Watching
      Baker518
      I really like the possibilities and potential this script has. This is superb work.
      ...but, I have a question? When I pull the off-set, the edges are contoured, so they don't have a discernible face to each side. Is this correct or am I doing something wrong?
      Let me know and thanks again, this is a gem for sure
      Mike
      Don't worry about things you have no control over. Worry is a lack of Faith!
        Razor681
        Fredo, this thing is AWESOME!!!!!
        Your plugin ROCKS!
        ๐Ÿ˜ ๐Ÿ˜ ๐Ÿ˜ ๐Ÿ˜ ๐Ÿ˜
        • fredo6F Offline
          fredo6
          Mike
          Mike,
          I suspect this is related to the question of edge style but I am afraid I would need a picture or a SKP sample to see what is the problem, and if this is a problem that can be solved. Thanks to post it.
          Fredo
            Baker518
            Here you go Fred
            Offset test.skp
            • fredo6F Offline
              fredo6
              I think I understand now.
              When you offset, the new contour is generated as a curve (you can change this by toggling F9).
              Then, a Joint Push Pull will consider that because the contour is a curve, the edges have to be generated as Soft and Smooth. This behavior actually is natural in most situations where you push pull a curved surface (for instance generated from Sand Box).
              Of course, it is possible to introduce options for all these behaviors, as it would anyway difficult for the script to decide by itself!
                juanjo06
                thanks guys.... in the plugins crai web this script is not working... maybe this realy does ๐ŸŽ‰
                • E Offline
                  Einstein
                  Hi!
                  I know, it's a dusted thread but maybe someone will make me know.
                  Is it possible that Offset on Surface would treat separately several neighbouring surfaces selected at one time? I mean, instead of creating one big offset from selection border, it would make several offsets, each out of one surface separately.
                  • fredo6F Offline
                    fredo6
                    @einstein said:
                    Hi!
                    Not sure I understand. Could you be more precise or give a concrete example.
                    Fredo
                    PS: you can use the Thread of ToolsOnSurface, or start a new discussion thread for this subject.
                    • 3 / 3
