    Script Request/Idea - MultiConstruction lines
    2 Posts 2 Posters 1.2k Views 2 Watching
    • Paul RussamP
      Paul Russam
      Many years ago I worked on GDS, it had a wonderful feature(s) called RuleX, RuleY and RuleA.
      You could type RuleX 0 300 5400 150 2000 300 and get a horizontal line(X) at the point that you clicked, 300mm up from that, 5400mm up again, 150 up again etc.
      RuleY was the same but produced vertical lines and RuleA required 2 clicks and produced lines aligned with those 2 points.
      You could type negative numbers to produce lines going in the opposite direction.
      You could get distances to repeat, for example RuleX 0 100 200 100r5 300 would produce lines at 0,100,200,100,100,100,100,100,300.
      Could a ruby make use of the ruler in SU to do such a script(s) RuleX, RuleY, RuleZ & RuleA ?.
      Could it be one command, as in click on a line and then a direction, or 2 clicks to establish a base line and then a third to establish a direction?
      Just a thought.
      Paul Russam
      English doesn't borrow from other languages. It follows them down dark allies, knocks them over, and goes through their pockets for loose grammar.
      • TIGT
        There are already several Rubies out there that make grids of clines at XY (and Z) spacings - grid.rb, 3d_grid.rb, numbered_grid.rb etc. There's also a parametric 2D version you can adjust later on - think that's on SUp site ?
        Search in Didier's Ruby Library Depot site...
