    Script Request/Idea - MultiConstruction lines
    2 Posts 2 Posters 1.1k Views 2 Watching
    • Paul RussamP Offline
      Paul Russam
      Many years ago I worked on GDS, it had a wonderful feature(s) called RuleX, RuleY and RuleA.
      You could type RuleX 0 300 5400 150 2000 300 and get a horizontal line(X) at the point that you clicked, 300mm up from that, 5400mm up again, 150 up again etc.
      RuleY was the same but produced vertical lines and RuleA required 2 clicks and produced lines aligned with those 2 points.
      You could type negative numbers to produce lines going in the opposite direction.
      You could get distances to repeat, for example RuleX 0 100 200 100r5 300 would produce lines at 0,100,200,100,100,100,100,100,300.
      Could a ruby make use of the ruler in SU to do such a script(s) RuleX, RuleY, RuleZ & RuleA ?.
      Could it be one command, as in click on a line and then a direction, or 2 clicks to establish a base line and then a third to establish a direction?
      Just a thought.
      Paul Russam
      English doesn't borrow from other languages. It follows them down dark allies, knocks them over, and goes through their pockets for loose grammar.
        There are already several Rubies out there that make grids of clines at XY (and Z) spacings - grid.rb, 3d_grid.rb, numbered_grid.rb etc. There's also a parametric 2D version you can adjust later on - think that's on SUp site ?
        Search in Didier's Ruby Library Depot site...
