    Ruby Console Ruby Console
    19 Posts 7 Posters 3.6k Views 7 Watching
      SchreiberBike
      Under my Windows pull down menu, the last item is "Ruby Console". Just above that is "Ruby Console".
      Does everyone have this embarrassment of riches? I don't think they've both aways been there, but I don't know when the 2nd one appeared. It's not a problem, but it's odd.
        I used have the same. Some ruby puts it there (maybe just because when upgrading to SU5 I just copied most of my old stuff to SU6). I cannot remember the solution but some ruby scripter enlightened me, poor erthly mortal what to do and I got rid of it (not as if it had bothered me either - I was just curious, too).
          todd burch
          If you have a sketchup.rb in /Plugins, get rid of it. It's only supposed to be in /Tools.
          Todd
            Ah, that's it. Thanks, Todd.
            • jujuJ Offline
              juju
              I have the same problem (2x ruby console entries below each other), however I don't have a sketchup.rb file in the plugins folder.
                todd burch
                There's another script out there that is errant.
                It issues a "sendAction" to display the console, just as if you clicked on the dropdown choice. Search you plugins folder for any script that mentions "console" and you'll probably find it.
                Once you find it, show us the code and we'll tell you how to comment it out.
                Todd
                  SchreiberBike
                  I haven't been able to work it out yet. It's a small problem, so I haven't chased it too hard, but I tried your suggestions and didn't have any luck.
                  There's no extra sketchup.rb in Plugins.
                  I searched for "console" and found it in the comments of Examples.rb, utilitietools.rb and
                  examplescripts.rb.
                  The ruby sketchup.rb has the word console as part of
                  if( not file_loaded? "sketchup.rb" )
                  Add a choice to the Window menu to display the Ruby console
                  add_separator_to_menu("Window")
                  UI.menu("Window").add_item($suStrings.GetString("Ruby Console")) do
                  Sketchup.send_action("showRubyPanel:")
                  and
                  require 'langhandler.rb'
                  $suStrings = LanguageHandler.new("gettingstarted.strings")
                  console
                  This file defines a number of useful utilities that are used by other
                  Ruby scripts.
                  Do you think it could be one of those?
                  • TIGT Online
                    Search for "showRubyPanel" in Plugins and Tools folders...
                    It's that name that's called. I accidentally left a call in ComponentReporter.rb about three years ago but all subsequent versions were fixed... Maybe it's something like that ?
                      todd burch
                      Thanks TIG. I was working from failing memory.
                        SchreiberBike
                        Still not seeing single ๐Ÿค“ (closest I could find to an emoticon seeing double)
                        In SketchyPhysics, I found
                        if( not file_loaded?("SketchyPhysics.rb") )
                        #result = Sketchup.send_action "showRubyPanel:"
                        reload()
                        but deleting that file and other references to SketchyPhysics didn't make any change.
                        I did find it in sketchup.rb in the tools directory
                        Add some Ruby specific menu items
                        Commenting that out got rid of both copies, but I do want one of them.
                          todd burch
                          AHA! Perhaps you have a script that performs a LOAD of sketchup.rb instead of requiring it. Now search for "sketchup.rb" (a case insensitive search) and see what you come up with.
                          FYI - Any line of Ruby code that starts with a hash sign ("#") is a comment.
                          Todd
                            SchreiberBike
                            Still no luck. The only references to sketchup.rb are Require, except in the file sketchup.rb itself.
                            It's not bothering me much, but if I have time to spare, I'll uninstall SU and the rubys, then reinstall them and watch to see if and when the 2nd "ruby console" reappears.
                              John,
                              Do you have the sketchup.rb in your plugins folder? And what's the file size?
                                todd burch
                                If you want, and you won't be breaking any licensing agreements, zip up up your /plugins folder and send it to me and I'll figure it out.
                                Todd
                                  SchreiberBike
                                  Gaieus, The only sketchup.rb I've got is in the /tools folder. It's 4K.
                                  Todd, I'll live with it for now, unless it's making you curious, then I'll send it to you for you to play with.
                                    Jim
                                    It's making me curious.
                                      ryan_allan
                                      Jim,
                                      I'd like to say this is a Sketchup bug. I loaded Sketchup with an empty plugins folder, punched "require 'Sketchup.rb'" into the console window, and instantly had the second Ruby Console on the menu.
                                        todd burch
                                        Ryan, that's because you typed "Sketchup.rb" with a capital "S". sketchup.rb does not perform a case insensitive compare when comparing script names. This has worked this way since June 2004, and was reported at least 2 years ago to @Last / Google, and a workaround even given too.
                                        Todd
                                          ryan_allan
                                          Well, sorry for replicating an already known bug... on the upside, now I fixed the same bug in my own code. Thanks Todd!
