    Ruby Console Ruby Console
    19 Posts 7 Posters 3.8k Views 7 Watching
      SchreiberBike
      Still not seeing single πŸ€“ (closest I could find to an emoticon seeing double)
      In SketchyPhysics, I found
      if( not file_loaded?("SketchyPhysics.rb") )
      #result = Sketchup.send_action "showRubyPanel:"
      reload()
      but deleting that file and other references to SketchyPhysics didn't make any change.
      I did find it in sketchup.rb in the tools directory
      Add some Ruby specific menu items
      if( not file_loaded? "sketchup.rb" )
      Add a choice to the Window menu to display the Ruby console
      add_separator_to_menu("Window")
      UI.menu("Window").add_item($suStrings.GetString("Ruby Console")) do
      Sketchup.send_action("showRubyPanel:")
      Commenting that out got rid of both copies, but I do want one of them.
      • T
        todd burch
        AHA! Perhaps you have a script that performs a LOAD of sketchup.rb instead of requiring it. Now search for "sketchup.rb" (a case insensitive search) and see what you come up with.
        FYI - Any line of Ruby code that starts with a hash sign ("#") is a comment.
        Todd
          SchreiberBike
          Still no luck. The only references to sketchup.rb are Require, except in the file sketchup.rb itself.
          It's not bothering me much, but if I have time to spare, I'll uninstall SU and the rubys, then reinstall them and watch to see if and when the 2nd "ruby console" reappears.
          • GaieusG
            John,
            Do you have the sketchup.rb in your plugins folder? And what's the file size?
            • T
              todd burch
              If you want, and you won't be breaking any licensing agreements, zip up up your /plugins folder and send it to me and I'll figure it out.
              Todd
                SchreiberBike
                Gaieus, The only sketchup.rb I've got is in the /tools folder. It's 4K.
                Todd, I'll live with it for now, unless it's making you curious, then I'll send it to you for you to play with.
                  Jim
                  It's making me curious.
                    ryan_allan
                    Jim,
                    I'd like to say this is a Sketchup bug. I loaded Sketchup with an empty plugins folder, punched "require 'Sketchup.rb'" into the console window, and instantly had the second Ruby Console on the menu.
                    • T
                      todd burch
                      Ryan, that's because you typed "Sketchup.rb" with a capital "S". sketchup.rb does not perform a case insensitive compare when comparing script names. This has worked this way since June 2004, and was reported at least 2 years ago to @Last / Google, and a workaround even given too.
                      Todd
                        ryan_allan
                        Well, sorry for replicating an already known bug... on the upside, now I fixed the same bug in my own code. Thanks Todd!
