    Ruby Console Ruby Console
    19 Posts 7 Posters 3.6k Views 7 Watching
      Search for "showRubyPanel" in Plugins and Tools folders...
      It's that name that's called. I accidentally left a call in ComponentReporter.rb about three years ago but all subsequent versions were fixed... Maybe it's something like that ?
        todd burch
        Thanks TIG. I was working from failing memory.
          SchreiberBike
          Still not seeing single πŸ€“ (closest I could find to an emoticon seeing double)
          In SketchyPhysics, I found
          if( not file_loaded?("SketchyPhysics.rb") )
          #result = Sketchup.send_action "showRubyPanel:"
          reload()
          but deleting that file and other references to SketchyPhysics didn't make any change.
          I did find it in sketchup.rb in the tools directory
          Add some Ruby specific menu items
          if( not file_loaded? "sketchup.rb" )
          Add a choice to the Window menu to display the Ruby console
          add_separator_to_menu("Window")
          UI.menu("Window").add_item($suStrings.GetString("Ruby Console")) do
          Sketchup.send_action("showRubyPanel:")
          Commenting that out got rid of both copies, but I do want one of them.
            todd burch
            AHA! Perhaps you have a script that performs a LOAD of sketchup.rb instead of requiring it. Now search for "sketchup.rb" (a case insensitive search) and see what you come up with.
            FYI - Any line of Ruby code that starts with a hash sign ("#") is a comment.
            Todd
              SchreiberBike
              Still no luck. The only references to sketchup.rb are Require, except in the file sketchup.rb itself.
              It's not bothering me much, but if I have time to spare, I'll uninstall SU and the rubys, then reinstall them and watch to see if and when the 2nd "ruby console" reappears.
                John,
                Do you have the sketchup.rb in your plugins folder? And what's the file size?
                  todd burch
                  If you want, and you won't be breaking any licensing agreements, zip up up your /plugins folder and send it to me and I'll figure it out.
                  Todd
                    SchreiberBike
                    Gaieus, The only sketchup.rb I've got is in the /tools folder. It's 4K.
                    Todd, I'll live with it for now, unless it's making you curious, then I'll send it to you for you to play with.
                      Jim
                      It's making me curious.
                        ryan_allan
                        Jim,
                        I'd like to say this is a Sketchup bug. I loaded Sketchup with an empty plugins folder, punched "require 'Sketchup.rb'" into the console window, and instantly had the second Ruby Console on the menu.
                          todd burch
                          Ryan, that's because you typed "Sketchup.rb" with a capital "S". sketchup.rb does not perform a case insensitive compare when comparing script names. This has worked this way since June 2004, and was reported at least 2 years ago to @Last / Google, and a workaround even given too.
                          Todd
                            ryan_allan
                            Well, sorry for replicating an already known bug... on the upside, now I fixed the same bug in my own code. Thanks Todd!
