Calculate area
I seem to remember there was a tool to calculate the sq ft area from within SketchUp
any info or link appreciated
~ian
select the surfaces you'd like to measure then right click -> entity info... the area will be listed there..
Thanks Jeff
found it in SELECT/AREA afte selecting and right-clicking~ian
Hi folks.
You can also use the Text Tool. The default text is:
X,Y,Z coordinates for end points;
Length for lines;
Area for faces;
Name for components and groups (if named, otherwise "Group" will show as the default name).
Just ideas.
Register LoginAdvertisement
