    Calculate area
    4 Posts 3 Posters 19.2k Views 3 Watching
    • I Offline
      ianccc
      I seem to remember there was a tool to calculate the sq ft area from within SketchUp
      any info or link appreciated
      ~ian
      • jeff hammondJ Offline
        select the surfaces you'd like to measure then right click -> entity info... the area will be listed there..
        • I Offline
          ianccc
          Thanks Jeff
          found it in SELECT/AREA afte selecting and right-clicking
          ~ian
          • Jean LemireJ Offline
            Jean Lemire
            Hi folks.
            You can also use the Text Tool. The default text is:
            • X,Y,Z coordinates for end points;
            • Length for lines;
            • Area for faces;
            • Name for components and groups (if named, otherwise "Group" will show as the default name).
            Just ideas.
