    ⌛ Sale Ending | 30% Off Profile Builder 4 ends 30th September
    [Plugin] SketchyFFD (Classic)
    412 Posts 153 Posters 420.4k Views 153 Watching
      rshah
      Hi..
      I am trying this ruby but doesnt work. I create a simple circle and pull it to give it a height. i then select everything and create group. I then select group and right click and it lets me do 3x3 etc point cloud. When i go into points group and move some points and close group and then right click on geometry group then i dont see update FFD tool. Can someone please help?
      I am using sketchup 6 pro
      thansk in anticipation.
      • jujuJ Offline
        juju
        The ruby works as advertised. I think you need to revisit your steps and have a careful look at how to use the ruby again. Make sure it has subdivided geometry to work with though.
          tourniquetmaster
          My deformations are not auto updating themselves. Would anyone happen to know why?
            remus
            It might just be taking a while to work out whats meant to be happeneing or SU might be taking a while to display the deformed geometry.
              shnash
              I have downloaded your program sketchy FFD and have put it in the plugins folder. I see it in sketchup when i right click but when i apply it to a group i do not see the update ffd option. can u please tell me wot I'm doing wrong? thanks
                remus
                If youve got the latest version you shouldnt need the update option, it should do it automatically.
                • K Offline
                  kwistenbiebel
                  Not always. as a matter of fact I would vote to get the 'update' button re-instated, just for the cases the auto-update doesn't work.
                    CPhillips
                    Yeah, the update menu option was removed when I figured out how to auto update. Ill remove it from the post.
                    I can put it back. But I would rather fix the bug that keeps auto updating from working. Can you send me a model that the FFD doesn't auto update I might be able to figure it out.
                      andrew1184
                      Wonderful plugin, thank you very much. If I do anything useful I'll try to upload it . . .
                        aby
                        cheer man u are rockin
                        for base users like me ur genius
                        go on
                          REGIS
                          Hi CPhillips, it appears that your very great plugin doesn't work within google sketchup 7.
                          Any idea ?
                          Thanks in advance
                          cheers
                            CPhillips
                            I'll post an updated version tonight.
                            Chris
                              sepo
                              Nice one Chris. Will the updated version be any different than previous and will it work with SU6?
                                REGIS
                                Thanks a lot CPhilips, I really enjoy your plugin.
                                cheers
                                  CPhillips
                                  I just tried it out under SU7 (free version) and it seems to work ok. How is it failing for you?
                                  Chris
                                    REGIS
                                    Hi the FFD menu doesn't appear in contextual menu.
                                    cheers
                                      CPhillips
                                      Are you sure you installed it in the right place. Should be in the plugins folder.
                                      Can anyone else confirm it does or doesn't work with SU7?
                                        johnsenior1973
                                        FFD isn't appearing for me in SU7.
                                        It's probably my fault for trying to copy the plugins straight from 6 to 7 though.
                                          johnsenior1973
                                          Downloaded it again and installed it. It's working for me now.
                                            REGIS
                                            downloaded and installed in google sketchup 7 plugins folder.
                                            Doesn't work
                                            cheers
                                            • 7
                                            • 8
                                            • 9
                                            • 10
                                            • 11
                                            • 20
                                            • 21
                                            • 9 / 21
