    Could this be the answer to our Energy Needs ?
    30 Posts 17 Posters 2.3k Views 17 Watching
      You can't get something for nothing - it is a basic thermodynamic law... BUT you can move energy around to where you want it. Even Steorn fell into the trap of saying that their [now found to be flawed] gizmo 'broke the laws of the universe' ! ๐Ÿ˜’
      It didn't need to for it to produce more energy out of itself than you put in... I know at first glance this seems oxymoronic BUT just think about things you see every day... โ“
      A fridge/aircon unit moves heat energy from one place to another - it's not magic. A heat-pump uses 1kW of electricity but outputs say 3kW of heat - where'd that extra 2kW come from? it wasn't 'made', it was simply moved from somewhere else and 'concentrated' to useful levels - e.g. low-grade heat in ground-water or outside-air is moved into your home as useful heat to keep you warm. This does not break any 'laws' of the universe as the total amount of energy remains unchanged - it's just in a different place - your home is quite a bit warmer and outside is a tiny bit colder - since there's a lot more 'outside' than there is 'inside' the affects on the 'global' outside temperature is barely measurable. ๐Ÿ˜ฎ
      So what does this mean? Well, my point is that if you can do this with simple heat energy it must be theoretically possible to make a gizmo that gets low level energy from other sources - e.g. the flux of the earth's magnetic-field or the solar-winds etc and then makes it available to you in a concentrated local form that's useful... Since electro-magnetic and electrical fields pervade everything it must be possible to 'tap' into them and 'borrow' some of that energy - it'd not be 'making it', it'd just be moving it to where it's needed in a useful form... โ˜€ ๐Ÿ’ญ
      • Mike LuceyM Offline
        Mike Lucey
        I think you are right TIG in what you say. 'Moving' should be the operative word not creating by means of magic!
        I might pop up to Dublin a have a look at the machine in the new year! Check out this article 'Roll up, roll up to see the Irish perpetual motion machine!' http://www.gizmag.com/steorn-orbo-perpetual-motion-demonstration/13625/?utm_source=Gizmag+Subscribers&utm_campaign=50d4d4bdbb-UA-2235360-4&utm_medium=email
        Tomaz, yes, I wonder why a 'decent' (size) capacitor was not used at least for the ongoing running of the machine, maybe with a battery to kick it off.
        Mike
        • pbacotP Offline
          Like most start-ups and speculation, I think the important thing is to move money, not energy, from one location to another.
            tomasz
            Introduction to an Orbo Electromagnetic Interaction - Part 1
            http://www.youtube.com/watch?v=S5nae_I_Mus
              Jackson
              ROFLMAO! ๐Ÿคฃ
              How true... from the pockets of gullible people to the off-shore bank accounts of con-men.
              Jackson
              • FletchF Offline
                Fletch
                original links in all first post are now defunct... adding weight to the conspiracy theories... ๐Ÿ˜„
                Fletch
                3D Modeling addict. Former owner/developer of Twilight Render. sleepinggiantvisual.com
                • N Offline
                  notareal
                  +1
                  We got also a local "celebrancy" with free energy iniative... so far best he has done was moving some loose money to his own pockets. I prefer not to link to his ventures, but if you really want to find out, search for "utele theory". ๐Ÿ˜’
                    Mike Lucey
                    Came across 'New Japanese technology to solve world fuel crisis' recently at http://www.youtube.com/watch?v=2fg0xeZSF0E Maybe worth looking at while having some beans on toast and a bottle of Coke ๐Ÿ˜‰
                    • N Offline
                      notareal
                      Did make a quick google search with technology terms used in vid 'New Japanese technology to solve world fuel crisis' and got this http://www.modelmayhem.com/po.php?thread_id=470664
                      Seriously hope that these cars have no 'gas' problems. ๐Ÿ˜‰
                      (seems that there was a blurry hint in the image)
                        tomasz
                        An update. They have prepared a solid state version that has no moving parts.
                        YouTube - Testing of the Orbo Evaluation and Development Unit
                        by SteornOfficial
                        [flash=480,385:imi65ah9]http://www.youtube.com/v/_HKTYrVjEGY?fs=1&hl=pl_PL[/flash:imi65ah9]
                        • 2 / 2
