    Smoothing issue?
    20 Posts 7 Posters 2.9k Views 7 Watching
    • chippwaltersC Offline
      chippwalters
      Hi all,
      I've got a problem. I've created 1/2 a model and want to mirror it to the other half, which I do using components. Now I want the polygons of the components to smooth correctly across the seam and was wondering if anyone knew of a good way to do this?
      Here's a pic showing the problem and a file which demonstrates it.
      FILE: http://www.gadgetplugins.com/chippstuff/smoothingProblem.skp
      http://www.gadgetplugins.com/chippstuff/smoothingProblem.jpg
      Currently working with Cross-Reality technologies
      • DanielD Offline
        Daniel
        Probably the best way to avoid that would be to increase the number of segment in your arch. After drawing your arc (and before you extrude the shape), click select the curve, right click and open the entity info window - you should see the number of segments displayed. Change that number until the curve appears as smooth as you like.
        My avatar is an anachronism.
          SchreiberBike
          Do you mean like this?A 13 segment arc added to the original, then cut in half, copied into two instances of the same component (one scaled to -1) and moved next to each other. Then pulled out.smoothingSolution.skp
          It's still divided into two components, but for the original arc, I made it from a 13 sided curve rather than the usual 12. That way, the middle side is cut in half and the two halves of that line are co-planer and adjoining.
          I learned this trick just the other day right here in this community.
          It also works for circular objects. Divide someplace other than at an intersection and the shading works right.
            chippwalters
            Brillant! Thanks for the tip. It of course makes sense.
            • G Offline
              Gidon Yuval
              Oooooooooooooooooooh! Very crafty John!
              13 faces, cut the middle one in half and join the co-planer halves.
              Fiendishly elegant solution 👿!
              If you don't know where you're going, you're never going to get there.
              • P Offline
                Pagan
                Problem is gone when you explode left and right side.
                But this is smooth.
                  chippwalters
                  Yeah, I know. But I wanted to keep the components 'intact'. Thanks for sharing.
                    Hi Chipp,
                    The "default" (24 segmented) circle fulfils this formula: 11*2=22+2=24 and is still not smooth when creating a cylinder from it.
                      chippwalters
                      OOPS! Thanks for pointing that out.
                      The formula should just be:
                      The number of sides for the circle = (any odd number * 2)
                      Here's a tute which shows it.
                      http://www.gadgetplugins.com/chippstuff/SmoothMirrorModelingAndCylinders.skp
                        chippwalters
                        So, for those still here, and interested. To create a cylindrical surface, and work on only 1/2 (or 1/4) of it as a component, and have it STILL smooth correctly, use this formula:
                        The number of sides for the circle = (any odd number * 2) + 2
                        EDITED: The number of sides for the circle = (any odd number * 2)
                        HTH, Chipp
                          Well, actually any circle can do that provided you split izt up at the midpoint not the endpoints. I remember a thread about this but simply cannot find it any more (funny though - I mostly know about everything that's going on here...) 😄
                            chippwalters
                            I don't understand what your saying. Of course any circle can be used this way, but only circles with the number of faces = odd number *2 can create the smooth seam on the front of the cylindrical surface WHILE the object is still a component. If you explode the mirrored components, then of course the seam can be smoothed.
                            The formula works only when you create a circle by clicking first on the center then next on a point which is 90 degrees from where the intended seam is to be. The trick, as explained above (and in my skp file), is to make a circle so that the front seam polyline HAS to be divided in half.
                            I hope I'm making myself clear...perhaps I'm not? Sorry...
                              Well, see the attached cylinder, based on the default (24 segmented) circle.
                              cylinder.skp
                                chippwalters
                                That skp doesn't use the component mirror example, which is the question at the top of this thread.
                                  Ah yes, that's tru. Sorry I went off-topic in this case totally forgetting what the original issue was. 😄
                                  But anyway, the idea is still the same. In your example you have also split the geometry at the midpoint of the polygon. This is possible and the resulting, mirrored geometry will look smooth because the matching faces are coplanar (not like when you split something at an endpoitnt).
                                  See these two cylinders here. One was split into half from endpoint to endpoint an then mirrored; you can see the seam. The other one from midpoint to midpoint; there is no seam.
                                  cylinder2.skp
                                    chippwalters
                                    Exactly. You have to divide at a midpoint. My example shows the same. Thanks 😄
                                      chippwalters
                                      You should try repeating my example (using the cube as reference) and the default number of sides for your circle, and I think you'll see where I'm coming from. It's much easier to 'snap' to the end of the side of the cube using my equation.
                                        SchreiberBike
                                        Since the trick is to split along a flat surface, it doesn't really matter exactly how many surfaces a cylinder has. If it has 24 sides, and while making the cylinder the radius used was along one of the axes, rotating the cylinder 7.5° makes the face perpendicular to the axes line which you will probably use to halve or quarter the circle.
                                        On an unrelated note. All even numbers = any whole number*2. Just a bit of mathematical trivia.
                                        • Jean LemireJ Offline
                                          Jean Lemire
                                          Hi folks.
                                          If you want your splitting plane to be parallel the any standard plane (red-green or red blue or green-blue), you may rotate the circle (before extrusion) or cylinder (after extrusion).
                                          Use 7.5° if the circle has 24 segments.
                                          The formula is 180 ÷ number of segments.
                                          Just ideas.
                                            chippwalters
                                            Exactly...and that is what my skippy (and formula) are about. The whole idea is using the formula:
                                            number of sides of circle = any odd number * 2
                                            is so that one doesn't need to rotate the circle after creating it. See the skippy example and you'll see.
                                            best regards,
                                            Chipp
