    Smoothing issue?
    20 Posts 7 Posters 2.9k Views 7 Watching
      Hi Chipp,
      The "default" (24 segmented) circle fulfils this formula: 11*2=22+2=24 and is still not smooth when creating a cylinder from it.
      • chippwaltersC Offline
        chippwalters
        OOPS! Thanks for pointing that out.
        The formula should just be:
        The number of sides for the circle = (any odd number * 2)
        Here's a tute which shows it.
        http://www.gadgetplugins.com/chippstuff/SmoothMirrorModelingAndCylinders.skp
        Currently working with Cross-Reality technologies
          chippwalters
          So, for those still here, and interested. To create a cylindrical surface, and work on only 1/2 (or 1/4) of it as a component, and have it STILL smooth correctly, use this formula:
          The number of sides for the circle = (any odd number * 2) + 2
          EDITED: The number of sides for the circle = (any odd number * 2)
          HTH, Chipp
            Well, actually any circle can do that provided you split izt up at the midpoint not the endpoints. I remember a thread about this but simply cannot find it any more (funny though - I mostly know about everything that's going on here...) 😄
              chippwalters
              I don't understand what your saying. Of course any circle can be used this way, but only circles with the number of faces = odd number *2 can create the smooth seam on the front of the cylindrical surface WHILE the object is still a component. If you explode the mirrored components, then of course the seam can be smoothed.
              The formula works only when you create a circle by clicking first on the center then next on a point which is 90 degrees from where the intended seam is to be. The trick, as explained above (and in my skp file), is to make a circle so that the front seam polyline HAS to be divided in half.
              I hope I'm making myself clear...perhaps I'm not? Sorry...
                Well, see the attached cylinder, based on the default (24 segmented) circle.
                cylinder.skp
                  chippwalters
                  That skp doesn't use the component mirror example, which is the question at the top of this thread.
                    Ah yes, that's tru. Sorry I went off-topic in this case totally forgetting what the original issue was. 😄
                    But anyway, the idea is still the same. In your example you have also split the geometry at the midpoint of the polygon. This is possible and the resulting, mirrored geometry will look smooth because the matching faces are coplanar (not like when you split something at an endpoitnt).
                    See these two cylinders here. One was split into half from endpoint to endpoint an then mirrored; you can see the seam. The other one from midpoint to midpoint; there is no seam.
                    cylinder2.skp
                      chippwalters
                      Exactly. You have to divide at a midpoint. My example shows the same. Thanks 😄
                        chippwalters
                        You should try repeating my example (using the cube as reference) and the default number of sides for your circle, and I think you'll see where I'm coming from. It's much easier to 'snap' to the end of the side of the cube using my equation.
                          SchreiberBike
                          Since the trick is to split along a flat surface, it doesn't really matter exactly how many surfaces a cylinder has. If it has 24 sides, and while making the cylinder the radius used was along one of the axes, rotating the cylinder 7.5° makes the face perpendicular to the axes line which you will probably use to halve or quarter the circle.
                          On an unrelated note. All even numbers = any whole number*2. Just a bit of mathematical trivia.
                          • Jean LemireJ Offline
                            Jean Lemire
                            Hi folks.
                            If you want your splitting plane to be parallel the any standard plane (red-green or red blue or green-blue), you may rotate the circle (before extrusion) or cylinder (after extrusion).
                            Use 7.5° if the circle has 24 segments.
                            The formula is 180 ÷ number of segments.
                            Just ideas.
                              chippwalters
                              Exactly...and that is what my skippy (and formula) are about. The whole idea is using the formula:
                              number of sides of circle = any odd number * 2
                              is so that one doesn't need to rotate the circle after creating it. See the skippy example and you'll see.
                              best regards,
                              Chipp
