    πŸ«› Lightbeans Update | Metallic and Roughness auto-applied in SketchUp 2025+ Download
    Exploded views
    10 Posts 4 Posters 993 Views 4 Watching
    • W Offline
      Woodjoint
      Hi Folks,
      I just downloaded a sketch up drawing from a woodworking blog
      http://www.woodworking-magazine.com/blog/PermaLink,guid,59b7a213-f516-4a16-a135-37d90677fb2b.aspx
      Well I tried looking in help to find out how to take the drawing apart and see how the joints go together but I can't figure how to start. I got an x-ray view but have no idea how to get it apart. 😳
      Charlie Mastro
      http://www.mastrowoodworking.com
        remus
        The easiest way to go about this is to use the move tool to seperate ut the groups. All you have to do is select the piece you want to move, select the move tool (or keyboard shortcut m) and then move it.
        You can move things in the direction of the axis by forcing an inference, so once youve started using the move tool, hit one of the direction keys (left=greeen axis, right=red axis, up and down=blue axis) to move the piece in that direction.
        • W Offline
          Woodjoint
          Maybe this just isn't going to work. When I try to select any part it selects the whole drawing and all I can do is move the whole drawing. I'm going to write the author and see if he can tell me what I'm doing wrong or why I can't select componets. Thanks Remus
          Charlie Mastro
            remus
            Ok, try right clicking the modle and selecting 'explode', that should do it.
            • W Offline
              Woodjoint
              YES 😍
              That did it....
              Charlie Mastro
                Gidon Yuval
                Charlie hi,
                There's another thing you can do that will save you the trouble of having to move the different pieces around. After having exploded the model as Remus rightly suggested, go to:
                View > Component edit > hide rest of model
                What this does is that when you double click on any of the parts to put it into edit mode, the rest of the model dissappears making it easier to view the chosen part. You aren't actualy going to edit the part, but you will have a clearer, unobstructed view of it. Then just click anywhere outside the 'bounding box' and the rest of the model re-appears.
                If you don't know where you're going, you're never going to get there.
                • W Offline
                  Woodjoint
                  Thanks Gidon I'll try that. Next question........... How do you get it back together?
                  I saved the exploded view then when I closed the orginal I choose do not save changes.
                  Charlie Mastro
                    remus
                    For getting it back together, my suggestion would be to either save a copy somewhere (file->save copy) or to only move a few pieces at a time so that you can easily put the whole tihng back together when youve finished.
                    • EdsonE Offline
                      Edson
                      check the ExplodeImplode ruby script at smustard.com. it does exactly what you are after.
                      http://www.mahfuz.arq.br
                      • W Offline
                        Woodjoint
                        Thanks again πŸ˜›
                        Charlie Mastro
