    Curved_slanted_wall
    30 Posts 11 Posters 5.8k Views 11 Watching
    • L
      lapx
      My next challenge is to slope the top of the wall. That is the highest part would be at the smaller radius point and the low part would be at the end of the largest radius.
      At first glance I thought I could easily draw a rect and slope the top and intersect this form with spiral wall but ofcurse this will not give the desired result. Any ideas?
      edit: Maybe I need to do the top wall slope part before the scaling.
      • GaieusG
        Ah, sorry. Yes obvuiously it was a misunderstanding - the top of it is slanting - not the whole wall is tilting (damn - my bad English...) 😳
        • L
          lapx
          That's quite alright Gaeius. We at east know how to do this when it comes up.
          That's the great thing about this community is that in looking for solutions to one problem may solve another for someone else, so all is not lost.
          Have a wonderful weekend!
          • Wo3DanW
            Wo3Dan
            lapx,
            Here is my attempt in the attached skp.
            (partly Bob's solution integrated)
            CurvedTiltedWall.skp
            • G
              GreyHead
              That's neat - I didn't think of smooving to lift the spiral.
              Bob
              • G
                gorygreg
                lapx,
                As a newbie, I almost get this!
                I do remeber another tutorial by someone on the forum, who demonstrated the Scene 3 technique. The one that copies and flips 180 degrees to have a center point. Can you elaborate again one why this is done? Then I will fully get it!
                Great job!
                • L
                  lapx
                  Wo3Dan great job. One tip though, would it not be easier to use the contour from scratch in lieu of hand stitching? Just have to erase to to clean up excess.
                  • Wo3DanW
                    Wo3Dan
                    gorygreg,
                    My attempt to try to explain is in the attached skp.
                    Lapx,
                    Leaving the top face in the curved boundary when using the Smoove tool will often result in an irragular pattern of triangles. I find it hard to correct all these lines. Better to do hand stitching, letting you make small adjustments to make cross sections horizontal at the top (if necessary).
                    I don't know how you are going to apply the "contour from scratch" tool here.
                    Maybe I can learn something. In my opinion SU will make a mess of all the extra lines (edges) within the curves. So what did you mean?
                    Wo3Dan
                    Scaling symetrical object.skp
                    • G
                      GreyHead
                      I do remember another tutorial by someone on the forum, who demonstrated the Scene 3 technique. The one that copies and flips 180 degrees to have a center point. Can you elaborate again one why this is done? Then I will fully get it!
                      This is done here because we want to keep the inner end of the wall vertical. The scale tool will leave the 'center' of the shape unchanged. But the center of a spiral is not at the inner end (see spiral_1). Copy-rotating the spiral gives a new shape where the scaling center is at the center of rotation and when you scale this shape the center of the spiral remains unchanged.
                      Bob
                        dtrarch
                        lapX
                        Just back from ski trip so a little late to all this but if the attached is what you wanted just let me know.
                        dtr
                        Curved tilt wall+thickness.skp
                        • L
                          lapx
                          @Wo3Dan,
                          Great explaination on that scaling issue. I figued this was the case your explaination reaffirmed. Thanks!
                          On the "contour from scratch" I just selected the top edge of the wall and used SU's contour from scratch. From first glance it seamed to work fine with a little clean up.
                          I will look at it again.
                          @dtracrh,
                          My walls would be titlted out ward as it follows the path. However, I would be interested in
                          what method you chose to arrive at your conclusion.
                          • Wo3DanW
                            Wo3Dan
                            @lapx said:
                            @Wo3Dan,.......
                            lapx,
                            Now I see what you mean, not "contour from scratch" (and not "from scratch" either) but "From Contours".
                            And you are quite right, that works perfect when no height corrections are needed.
                            When you have both the inner and the outer curves selected (spirals in scene 4, without their connecting edges at beginning and end) and apply "From Contours" you get a very good result that only needs some cleaning up.
                            I guess I was to much focused on "what if height corrections are needed for horizontal cross sections at the top of the wall". Even though the curves are slanted it's best to apply "From Contours".
                            (Leaving the face in scene 3 > 4 will give bad results when applying the "Smoove" tool)
                            Well, as I said: "maybe I can learn something".
                            Thanks for the suggestion.
                            Wo3Dan
                            • L
                              lapx
                              Thanks for clearing that up for me 😳
                              • Wo3DanW
                                Wo3Dan
                                😳 <-- Why ❓
                                You drew my attention to something about the sadbox that I overlooked.
                                (keeps me sharp 😄 )
                                So that's at least worth a 'thanks' to you:!:
                                cheers,
                                Wo3Dan
                                  dtrarch
                                  Hi lapX
                                  Here is how my example was put together.
                                  I used your path and welded the spiral portion first.
                                  The spiral portion was then extruded up using the vertical line of the path with the [extrudeline]with vector ruby.
                                  This face was then extruded horizontally using the [jointpushpull] ruby.
                                  (the keep face option found using the [tab] key was selected and there it was.
                                  dtr
                                  • L
                                    lapx
                                    Thanks Guy's, not to get to far off base but how come autocad, desktop and revit don't have a forum like this? They could learn a lot from this place.
                                    cheers! 😄
                                    • Jean LemireJ
                                      Jean Lemire
                                      Hi Lapx, hi folks.
                                      See attached SU file for ideas.
                                      Curved and tilted wall.skp
                                      • AnssiA
                                        Anssi
                                        cheers! 😄
                                        http://www.augi.com/
                                        It's overorganized (too many subforums with overlapping topics) but overall not too bad. I just learnt a lot about dynamic blocks.
                                        Anssi
                                        • L
                                          lapx
                                          Hello Jean,
                                          How would you get your method to rise from a low point to high point. One advantage of your solution is the wall is same thickness from top to bottom.
                                          • Wo3DanW
                                            Wo3Dan
                                            @lapx said:
                                            Hello Jean,
                                            lapx,
                                            In this case smooving the top will not work.
                                            Intesection with a vertical cone (preferably high poly) will do the trick.
                                            Place the cone with its vert.axis right in the center of the bottom spiral.
                                            Check if the slope is UP all the way to the center after intersecting, it should be.
                                            (Otherwise undo and reposition the cone a bit)
                                            Note that there is a big difference between Jean's slanted wall and the previously uoloaded ones.
                                            His wall is equally slanted all the way along the spiral.
                                            Ours were going from 'slanted much' to almost vertical near the center. Due to scaling.
                                            (It depends on what you need)
                                            With Jean's wall go for the cone-intersection.
                                            Wo3Dan
