    Curved_slanted_wall
    30 Posts 11 Posters 6.1k Views 11 Watching
    • L
      lapx
      Geyhead,
      That's It! Thanks Greyhead. 😄
      • GaieusG
        Lapx,
        Please, see my post above and the attached skippy.
        • G
          GreyHead
          Is this more what you had in mind with the wall sloping?
          For this style:
          • Create a upright rectangle the height and width of the wall;
          • Place it at the center of the spiral (at the origin along the green axis);
          • Use the follow-me tool to copy it along the curve;
          • Select the top surface only and rotate copy through 180 (this is to provide a fixed center for the next step)
          • Select the top surface of the wall and the copy and scale about the center to get the outer end of the wall to match the slope you want.
          • Clean up and smooth lines.
          Bob
          Added jpg version as png is showing as 'extension deactivated'
          • L
            lapx
            Thanks Gaieus,
            I don't see that your wall tilts outward. I'm also trying to get it to slope in the z direction as well.
            • L
              lapx
              My next challenge is to slope the top of the wall. That is the highest part would be at the smaller radius point and the low part would be at the end of the largest radius.
              At first glance I thought I could easily draw a rect and slope the top and intersect this form with spiral wall but ofcurse this will not give the desired result. Any ideas?
              edit: Maybe I need to do the top wall slope part before the scaling.
              • GaieusG
                Ah, sorry. Yes obvuiously it was a misunderstanding - the top of it is slanting - not the whole wall is tilting (damn - my bad English...) 😳
                • L
                  lapx
                  That's quite alright Gaeius. We at east know how to do this when it comes up.
                  That's the great thing about this community is that in looking for solutions to one problem may solve another for someone else, so all is not lost.
                  Have a wonderful weekend!
                  • Wo3DanW
                    Wo3Dan
                    lapx,
                    Here is my attempt in the attached skp.
                    (partly Bob's solution integrated)
                    CurvedTiltedWall.skp
                    • G
                      GreyHead
                      That's neat - I didn't think of smooving to lift the spiral.
                      Bob
                      • G
                        gorygreg
                        lapx,
                        As a newbie, I almost get this!
                        I do remeber another tutorial by someone on the forum, who demonstrated the Scene 3 technique. The one that copies and flips 180 degrees to have a center point. Can you elaborate again one why this is done? Then I will fully get it!
                        Great job!
                        • L
                          lapx
                          Wo3Dan great job. One tip though, would it not be easier to use the contour from scratch in lieu of hand stitching? Just have to erase to to clean up excess.
                          • Wo3DanW
                            Wo3Dan
                            gorygreg,
                            My attempt to try to explain is in the attached skp.
                            Lapx,
                            Leaving the top face in the curved boundary when using the Smoove tool will often result in an irragular pattern of triangles. I find it hard to correct all these lines. Better to do hand stitching, letting you make small adjustments to make cross sections horizontal at the top (if necessary).
                            I don't know how you are going to apply the "contour from scratch" tool here.
                            Maybe I can learn something. In my opinion SU will make a mess of all the extra lines (edges) within the curves. So what did you mean?
                            Wo3Dan
                            Scaling symetrical object.skp
                            • G
                              GreyHead
                              I do remember another tutorial by someone on the forum, who demonstrated the Scene 3 technique. The one that copies and flips 180 degrees to have a center point. Can you elaborate again one why this is done? Then I will fully get it!
                              This is done here because we want to keep the inner end of the wall vertical. The scale tool will leave the 'center' of the shape unchanged. But the center of a spiral is not at the inner end (see spiral_1). Copy-rotating the spiral gives a new shape where the scaling center is at the center of rotation and when you scale this shape the center of the spiral remains unchanged.
                              Bob
                                dtrarch
                                lapX
                                Just back from ski trip so a little late to all this but if the attached is what you wanted just let me know.
                                dtr
                                Curved tilt wall+thickness.skp
                                • L
                                  lapx
                                  @Wo3Dan,
                                  Great explaination on that scaling issue. I figued this was the case your explaination reaffirmed. Thanks!
                                  On the "contour from scratch" I just selected the top edge of the wall and used SU's contour from scratch. From first glance it seamed to work fine with a little clean up.
                                  I will look at it again.
                                  @dtracrh,
                                  My walls would be titlted out ward as it follows the path. However, I would be interested in
                                  what method you chose to arrive at your conclusion.
                                  • Wo3DanW
                                    Wo3Dan
                                    @lapx said:
                                    @Wo3Dan,.......
                                    lapx,
                                    Now I see what you mean, not "contour from scratch" (and not "from scratch" either) but "From Contours".
                                    And you are quite right, that works perfect when no height corrections are needed.
                                    When you have both the inner and the outer curves selected (spirals in scene 4, without their connecting edges at beginning and end) and apply "From Contours" you get a very good result that only needs some cleaning up.
                                    I guess I was to much focused on "what if height corrections are needed for horizontal cross sections at the top of the wall". Even though the curves are slanted it's best to apply "From Contours".
                                    (Leaving the face in scene 3 > 4 will give bad results when applying the "Smoove" tool)
                                    Well, as I said: "maybe I can learn something".
                                    Thanks for the suggestion.
                                    Wo3Dan
                                    • L
                                      lapx
                                      Thanks for clearing that up for me 😳
                                      • Wo3DanW
                                        Wo3Dan
                                        😳 <-- Why ❓
                                        You drew my attention to something about the sadbox that I overlooked.
                                        (keeps me sharp 😄 )
                                        So that's at least worth a 'thanks' to you:!:
                                        cheers,
                                        Wo3Dan
                                          dtrarch
                                          Hi lapX
                                          Here is how my example was put together.
                                          I used your path and welded the spiral portion first.
                                          The spiral portion was then extruded up using the vertical line of the path with the [extrudeline]with vector ruby.
                                          This face was then extruded horizontally using the [jointpushpull] ruby.
                                          (the keep face option found using the [tab] key was selected and there it was.
                                          dtr
                                          • L
                                            lapx
                                            Thanks Guy's, not to get to far off base but how come autocad, desktop and revit don't have a forum like this? They could learn a lot from this place.
                                            cheers! 😄
