    Archimedes screw - engineering help needed
    16 Posts 6 Posters 1.3k Views 6 Watching
      linea
      Wo3Dan
      Thanks for that, that's great 😄
      edit: just opened it, it's really great!
      • W Offline
        watkins
        Dear Jon,
        Presumably you would like some suggestions on how to manufacture the screw at a reasonable cost.
        May I start by suggesting you look for a supplier of plastic sewer pipe (or mains water supply pipe) as that looks to be a low cost option for the tube. Seeing as it is such a small piece, you may even get the company to supply FOC. The pipe should have a reasonable wall thickness (say around 10 mm)so that it doesn't distort under load. End pieces could be made from 25 mm thick plastic (polypropylene?) plate and fixed to the ends of the tube using M10 stainless steel studding running between the plates on the outside. The plastic end pieces could be machined to provide the bearing surfaces or you could use a suitable low friction plastic bearing, such as: http://www.igus.co.uk/iPro/iPro_02_0002_00_GBen.htm?ArtNr=&C=gb&L=en and add additional features to retain the bearings. [NB. I just did a quick search on the Web and so the choice of plastic bearing is probably not optimum, and perhaps not even close].
        The impellor is the tricky part as the edges of the screw have to 'wipe' the inner bore of the tube to minimise the flow back. Therefore, they have to be made accurately. Weldable plastic sheet (3 to 5 mm thick) might be used to make up the impellor blades. The sections could be water jet cut to high accuracy (a few tenths of a mm), shaped using a hot air gun (you will require a jig so that the forming can be done accurately), welded together to form the spiral impellor, and then welded to a plastic shaft (thick-walled plastic tube).
        As Jean would say, "just ideas".
        Kind regards,
        Bob
          linea
          Thanks watkins.
          • Paul RussamP Offline
            Paul Russam
            There's one of these at a place called Oxford Island Nature Centre on the shore of Lough Neigh (that's the big hole in the middle of Northern Island).
            If I remember correctly its about 600mm dia, and has a simple hand crank on the end instead of the wheel you have, this way a child could turn it as fast as they can!.
            I think its made from stainless steel.
            The size is almost identical to your sketch.
            It sits in a very shallow paddling pool with a sump similar to yours under the base.
            I'm unsure as to the sealing between the screw and the inner wall of the tube but I think there isn't any.
            If I remember right there is a 15-30mm round bar welded to the blade edge of the screw to prevent injury.
            I've looked online, but other than general area photos there are non of the play area, sorry
            Just a thought:
            Would a grain elevator from a combine harvester do the trick, the only other time I've seen them being used is at sewerage treatment plants to move the 'stuff' from sediment tank to sediment tank.
            Links I found:
            http://www.google.co.uk/imgres?imgurl=http://www.wittemuseum.org/images/Campus/Archimedes%2520Screw2.jpg&imgrefurl=http://www.wittemuseum.org/about_the_witte/index.html&h=93&w=125&sz=79&tbnid=TZLG36FwN1QJ;&tbnh=93&tbnw=125&prev=/images%3Fq%3DArchimedes%2Bscrew&sa=X&oi=image_result&resnum=1&ct=image&cd=3
            http://images.google.co.uk/imgres?imgurl=http://www.wwt.org.uk/images/gallery/wash_10_main.jpg&imgrefurl=http://www.wwt.org.uk/centre/123/washington.html&h=432&w=576&sz=90&hl=en&start=1&sig2=lxCLIEyztLboabJFTI9z4Q&um=1&tbnid=bvxKsevGgGtO4M;&tbnh=101&tbnw=134&ei=O5DaR8SkM5qYwwGqlMzRCA&prev=/images%3Fq%3DArchimedes%2Bscrew%2Bplay%26um%3D1%26hl%3Den%26safe%3Doff%26client%3Dfirefox-a%26rls%3Dorg.mozilla;en-GB;official%26sa%3DG
            Click on the No. 10 in the map
            Paul Russam
            English doesn't borrow from other languages. It follows them down dark allies, knocks them over, and goes through their pockets for loose grammar.
            • AnssiA Offline
              Anssi
              In the one I have seen (but don't remember where-some activity park I suppose) the tube and the "screw" turned together and the screw was tightly welded inside the tube, so no leaking.
              Anssi
                Paul Russam
                Ahhhh, Anssi, you got it, I knew that there was something I forgot about the one I saw, the tube and screw were turning together.
                Paul Russam
                  linea
                  Thanks Paul and Anssi. When I've drawn it up properly I'll post the result.
                    When you make the screw and the tube together, it actually works like those big concrete carrying trucks (or even the smaller concrete mixers). Examine them and you'll have the idea.
                    • W Offline
                      watkins
                      Dear Jon,
                      You have probably done your own search for suppliers, but see the attached file for UK manufacturers of screw conveyors. It is likely that you can design around standard parts, which would be a saving.
                      Regards,
                      Bob
                      Archimedes screw.txt
                        linea
                        Watkins your effort and help is great, thanks so much.
                        • W Offline
                          watkins
                          Dear Jon,
                          The engineering looks fun, and so I couldn't resist getting involved.
                          Regards,
                          Bob
