    Archimedes screw - engineering help needed
    16 Posts 6 Posters 900 Views 6 Watching
      linea
      I am re-writing this post - it was lost because of the reset.
      I am designing an activity garden for a school. We have an idea to build a working archimedes screw to raise water that the kids can play with. Do any engineering minded people out there have any tips about constructing an archimedes screw?
      archimedes.skp
      • W Offline
        watkins
        Dear Jon,
        Do you still require help, or is this a repeat because of the bug? What help do you need exactly?
        Kind regards,
        Bob
          linea
          Yet again Watkins, your in there staight away, us early morning people.
          Just a repeat post really. Thanks for the quick response, I just wondered if anybody had any experience or ideas about this. I know an excellent engineer who can fabricate this and I think I'll be fine when it comes to the working drawings, but just thought I'd post it here in case anybody had advice to offer.
          • W Offline
            watkins
            Dear Jon,
            I know an excellent engineer who is now retired. He has just got interested in Sketchup so I will pass on this link. He might have some advice. It would also be nice to have more engineers contributing to this forum.
            Good luck with the design.
            Regards,
            Bob
            • Wo3DanW Offline
              Wo3Dan
              Jon,
              The attached skp I made might help you a bit to see which way to go.
              (For kids you need to adjust the scale though 😉)
              And as an example of the helical screw see: (credit to NoelD this time)
              http://sketchup.google.com/3dwarehouse/details?mid=77d22eb035e66c59244b1e8fee0e9e34
              Wo3Dan
              pump1.skp
                linea
                Wo3Dan
                Thanks for that, that's great 😄
                edit: just opened it, it's really great!
                • W Offline
                  watkins
                  Dear Jon,
                  Presumably you would like some suggestions on how to manufacture the screw at a reasonable cost.
                  May I start by suggesting you look for a supplier of plastic sewer pipe (or mains water supply pipe) as that looks to be a low cost option for the tube. Seeing as it is such a small piece, you may even get the company to supply FOC. The pipe should have a reasonable wall thickness (say around 10 mm)so that it doesn't distort under load. End pieces could be made from 25 mm thick plastic (polypropylene?) plate and fixed to the ends of the tube using M10 stainless steel studding running between the plates on the outside. The plastic end pieces could be machined to provide the bearing surfaces or you could use a suitable low friction plastic bearing, such as: http://www.igus.co.uk/iPro/iPro_02_0002_00_GBen.htm?ArtNr=&C=gb&L=en and add additional features to retain the bearings. [NB. I just did a quick search on the Web and so the choice of plastic bearing is probably not optimum, and perhaps not even close].
                  The impellor is the tricky part as the edges of the screw have to 'wipe' the inner bore of the tube to minimise the flow back. Therefore, they have to be made accurately. Weldable plastic sheet (3 to 5 mm thick) might be used to make up the impellor blades. The sections could be water jet cut to high accuracy (a few tenths of a mm), shaped using a hot air gun (you will require a jig so that the forming can be done accurately), welded together to form the spiral impellor, and then welded to a plastic shaft (thick-walled plastic tube).
                  As Jean would say, "just ideas".
                  Kind regards,
                  Bob
                    linea
                    Thanks watkins.
                    • Paul RussamP Offline
                      Paul Russam
                      There's one of these at a place called Oxford Island Nature Centre on the shore of Lough Neigh (that's the big hole in the middle of Northern Island).
                      If I remember correctly its about 600mm dia, and has a simple hand crank on the end instead of the wheel you have, this way a child could turn it as fast as they can!.
                      I think its made from stainless steel.
                      The size is almost identical to your sketch.
                      It sits in a very shallow paddling pool with a sump similar to yours under the base.
                      I'm unsure as to the sealing between the screw and the inner wall of the tube but I think there isn't any.
                      If I remember right there is a 15-30mm round bar welded to the blade edge of the screw to prevent injury.
                      I've looked online, but other than general area photos there are non of the play area, sorry
                      Just a thought:
                      Would a grain elevator from a combine harvester do the trick, the only other time I've seen them being used is at sewerage treatment plants to move the 'stuff' from sediment tank to sediment tank.
                      Links I found:
                      http://www.google.co.uk/imgres?imgurl=http://www.wittemuseum.org/images/Campus/Archimedes%2520Screw2.jpg&imgrefurl=http://www.wittemuseum.org/about_the_witte/index.html&h=93&w=125&sz=79&tbnid=TZLG36FwN1QJ;&tbnh=93&tbnw=125&prev=/images%3Fq%3DArchimedes%2Bscrew&sa=X&oi=image_result&resnum=1&ct=image&cd=3
                      http://images.google.co.uk/imgres?imgurl=http://www.wwt.org.uk/images/gallery/wash_10_main.jpg&imgrefurl=http://www.wwt.org.uk/centre/123/washington.html&h=432&w=576&sz=90&hl=en&start=1&sig2=lxCLIEyztLboabJFTI9z4Q&um=1&tbnid=bvxKsevGgGtO4M;&tbnh=101&tbnw=134&ei=O5DaR8SkM5qYwwGqlMzRCA&prev=/images%3Fq%3DArchimedes%2Bscrew%2Bplay%26um%3D1%26hl%3Den%26safe%3Doff%26client%3Dfirefox-a%26rls%3Dorg.mozilla;en-GB;official%26sa%3DG
                      Click on the No. 10 in the map
                      http://onecityatatime.files.wordpress.com/2006/10/dsc07090_downrez.jpg
                      Paul Russam
                      English doesn't borrow from other languages. It follows them down dark allies, knocks them over, and goes through their pockets for loose grammar.
                      • AnssiA Offline
                        Anssi
                        In the one I have seen (but don't remember where-some activity park I suppose) the tube and the "screw" turned together and the screw was tightly welded inside the tube, so no leaking.
                        Anssi
                          Paul Russam
                          Ahhhh, Anssi, you got it, I knew that there was something I forgot about the one I saw, the tube and screw were turning together.
                          Paul Russam
                            linea
                            Thanks Paul and Anssi. When I've drawn it up properly I'll post the result.
                              When you make the screw and the tube together, it actually works like those big concrete carrying trucks (or even the smaller concrete mixers). Examine them and you'll have the idea.
                              • W Offline
                                watkins
                                Dear Jon,
                                You have probably done your own search for suppliers, but see the attached file for UK manufacturers of screw conveyors. It is likely that you can design around standard parts, which would be a saving.
                                Regards,
                                Bob
                                Archimedes screw.txt
                                  linea
                                  Watkins your effort and help is great, thanks so much.
                                  • W Offline
                                    watkins
                                    Dear Jon,
                                    The engineering looks fun, and so I couldn't resist getting involved.
                                    Regards,
                                    Bob
