    Archimedes screw - engineering help needed
    16 Posts 6 Posters 1.3k Views 6 Watching
    • L
      linea
      Yet again Watkins, your in there staight away, us early morning people.
      Just a repeat post really. Thanks for the quick response, I just wondered if anybody had any experience or ideas about this. I know an excellent engineer who can fabricate this and I think I'll be fine when it comes to the working drawings, but just thought I'd post it here in case anybody had advice to offer.
      • W
        watkins
        Dear Jon,
        I know an excellent engineer who is now retired. He has just got interested in Sketchup so I will pass on this link. He might have some advice. It would also be nice to have more engineers contributing to this forum.
        Good luck with the design.
        Regards,
        Bob
        • Wo3DanW
          Wo3Dan
          Jon,
          The attached skp I made might help you a bit to see which way to go.
          (For kids you need to adjust the scale though 😉)
          And as an example of the helical screw see: (credit to NoelD this time)
          http://sketchup.google.com/3dwarehouse/details?mid=77d22eb035e66c59244b1e8fee0e9e34
          Wo3Dan
          pump1.skp
          • L
            linea
            Wo3Dan
            Thanks for that, that's great 😄
            edit: just opened it, it's really great!
            • W
              watkins
              Dear Jon,
              Presumably you would like some suggestions on how to manufacture the screw at a reasonable cost.
              May I start by suggesting you look for a supplier of plastic sewer pipe (or mains water supply pipe) as that looks to be a low cost option for the tube. Seeing as it is such a small piece, you may even get the company to supply FOC. The pipe should have a reasonable wall thickness (say around 10 mm)so that it doesn't distort under load. End pieces could be made from 25 mm thick plastic (polypropylene?) plate and fixed to the ends of the tube using M10 stainless steel studding running between the plates on the outside. The plastic end pieces could be machined to provide the bearing surfaces or you could use a suitable low friction plastic bearing, such as: http://www.igus.co.uk/iPro/iPro_02_0002_00_GBen.htm?ArtNr=&C=gb&L=en and add additional features to retain the bearings. [NB. I just did a quick search on the Web and so the choice of plastic bearing is probably not optimum, and perhaps not even close].
              The impellor is the tricky part as the edges of the screw have to 'wipe' the inner bore of the tube to minimise the flow back. Therefore, they have to be made accurately. Weldable plastic sheet (3 to 5 mm thick) might be used to make up the impellor blades. The sections could be water jet cut to high accuracy (a few tenths of a mm), shaped using a hot air gun (you will require a jig so that the forming can be done accurately), welded together to form the spiral impellor, and then welded to a plastic shaft (thick-walled plastic tube).
              As Jean would say, "just ideas".
              Kind regards,
              Bob
              • L
                linea
                Thanks watkins.
                • Paul RussamP
                  Paul Russam
                  There's one of these at a place called Oxford Island Nature Centre on the shore of Lough Neigh (that's the big hole in the middle of Northern Island).
                  If I remember correctly its about 600mm dia, and has a simple hand crank on the end instead of the wheel you have, this way a child could turn it as fast as they can!.
                  I think its made from stainless steel.
                  The size is almost identical to your sketch.
                  It sits in a very shallow paddling pool with a sump similar to yours under the base.
                  I'm unsure as to the sealing between the screw and the inner wall of the tube but I think there isn't any.
                  If I remember right there is a 15-30mm round bar welded to the blade edge of the screw to prevent injury.
                  I've looked online, but other than general area photos there are non of the play area, sorry
                  Just a thought:
                  Would a grain elevator from a combine harvester do the trick, the only other time I've seen them being used is at sewerage treatment plants to move the 'stuff' from sediment tank to sediment tank.
                  Links I found:
                  http://www.google.co.uk/imgres?imgurl=http://www.wittemuseum.org/images/Campus/Archimedes%2520Screw2.jpg&imgrefurl=http://www.wittemuseum.org/about_the_witte/index.html&h=93&w=125&sz=79&tbnid=TZLG36FwN1QJ;&tbnh=93&tbnw=125&prev=/images%3Fq%3DArchimedes%2Bscrew&sa=X&oi=image_result&resnum=1&ct=image&cd=3
                  http://images.google.co.uk/imgres?imgurl=http://www.wwt.org.uk/images/gallery/wash_10_main.jpg&imgrefurl=http://www.wwt.org.uk/centre/123/washington.html&h=432&w=576&sz=90&hl=en&start=1&sig2=lxCLIEyztLboabJFTI9z4Q&um=1&tbnid=bvxKsevGgGtO4M;&tbnh=101&tbnw=134&ei=O5DaR8SkM5qYwwGqlMzRCA&prev=/images%3Fq%3DArchimedes%2Bscrew%2Bplay%26um%3D1%26hl%3Den%26safe%3Doff%26client%3Dfirefox-a%26rls%3Dorg.mozilla;en-GB;official%26sa%3DG
                  Click on the No. 10 in the map
                  Paul Russam
                  English doesn't borrow from other languages. It follows them down dark allies, knocks them over, and goes through their pockets for loose grammar.
                  • AnssiA
                    Anssi
                    In the one I have seen (but don't remember where-some activity park I suppose) the tube and the "screw" turned together and the screw was tightly welded inside the tube, so no leaking.
                    Anssi
                    • Paul RussamP
                      Paul Russam
                      Ahhhh, Anssi, you got it, I knew that there was something I forgot about the one I saw, the tube and screw were turning together.
                      Paul Russam
                      • L
                        linea
                        Thanks Paul and Anssi. When I've drawn it up properly I'll post the result.
                        • GaieusG
                          When you make the screw and the tube together, it actually works like those big concrete carrying trucks (or even the smaller concrete mixers). Examine them and you'll have the idea.
                          • W
                            watkins
                            Dear Jon,
                            You have probably done your own search for suppliers, but see the attached file for UK manufacturers of screw conveyors. It is likely that you can design around standard parts, which would be a saving.
                            Regards,
                            Bob
                            Archimedes screw.txt
                            • L
                              linea
                              Watkins your effort and help is great, thanks so much.
                              • W
                                watkins
                                Dear Jon,
                                The engineering looks fun, and so I couldn't resist getting involved.
                                Regards,
                                Bob
