    [Tutorial] Smooth Animations from Sketchup - WIP
    35 Posts 23 Posters 34.0k Views 23 Watching
    • boofredlayB
      boofredlay
      Thanks Paul.
      • O
        otb designworks
        Thanks Paul for this.
        Almost all my finished product involves animations so I am sure I'll learn something here. You must have a lot of patience to export at twice your desired size! A recent export of mine was 9750 frames@29.97 and it took something like 41 hours and that was at 1024 x 768 which was also my finished size! Needless to say, I broke it up into a bunch of smaller exports , but still.
        Any reason why you use Tiff instead of PNG? I always thought PNG's gave you lossless exports with a smaller file size than Tiff.
        The one thing I fight more than anything else is the dreaded moire. I wonder if you have any hints, short of avoiding moire prone textures, to minimize the flickering weirdness.
        Cheers, Chuck
        OTB Designworks is on Youtube
        • tinanneT
          tinanne
          This is great Paul! I'm starting a test run this weekend.
          Executive Director : American Society of Architectural Illustrators
          AIP 30 Competition opens soon. ASAI.org
          Architectural Rendering
          • KrisidiousK
            Krisidious
            fantastic Paul... thanks.
            By: Kristoff Rand
            • O
              otb designworks
              There is a remove flicker function in Primiere?! 8O
              I have been using quicktime pro and fotomagico for my compositing and it is getting to be time to drop the $800 (ouch) for Premiere. And this remove flicker really works? wow.
              Thanks Paul!
              Cheers, Chuck
              • N
                not registered yet
                wow, I had no idea animation from sketchup could be so intense!!!!!!!! I never even finished reading it. I had a client who wants to show a casket being put into a mosoleum animated.
                thanks anyway for your efffort.
                skip
                poster-Skip
                  mateo soletic
                  Thanks Paul. πŸ‘
                  Concept Illustrations
                  • K
                    kenzarch
                    Thanks Paul.
                    • Y
                      yaza
                      way to go πŸ‘ πŸ‘ 😍
                        arvmehta
                        Excellent tutorial , very similar to how are produce animations except for a twist , I don't use Premiere or After Effects but instead a piece of Free software (GNU GPL) called Mencoder . Using a commandline switch like
                        "d:\programs\mencoder\mencoder.exe" mf://*.jpg -mf fps=12:type=jpg -ovc lavc -lavcopts vcodec=mpeg4:vbitrate=12000 -oac copy -o output.avi -ffourcc XVID
                        I have compressed about 2500 1200x900 frames to Xvid format in under five minutes . Notice the vbitrate=12000 , Jacking it up really improved the picture quality . You can get Mencoder here .
                          anglaret
                          Paul
                          could you re-establish the link with your tutorial please, I would like to see it
                          Thanks - Marc
                          • Paul RussamP
                            Paul Russam
                            Umm, I don't seem to be able to get on the su.porta.ca site
                            I've set you a PM
                            Paul Russam
                            English doesn't borrow from other languages. It follows them down dark allies, knocks them over, and goes through their pockets for loose grammar.
                            • GaieusG
                              Hi Marc, Hi Paul,
                              I hope you have received Coen's board PM about Kelly's server and the transfer of the content into the current SCF server. I hope everything will be available again soon.
                              • Paul RussamP
                                Paul Russam
                                Thanks Guys, thought it was something along those lines.
                                Paul Russam
                                  StarWarsKnower
                                  The tutorial won't work. I click on the link, and it comes up in a new tab, then says 'HTTP Coulc Not Be Found'. Everyone says it is so good, I wan't to see it! 😞 😒 😞 😐
                                  Mike
                                  • GaieusG
                                    @starwarsknower said:
                                    ...Everyone says it is so good, I wan't to see it! 😞 😒 😞 😐
                                    True it is a great tut - be patient, please; the srever change is just being done (as you can read in your PM).
                                    • Paul RussamP
                                      Paul Russam
                                      OK, here's an updated Tut with the first part of the Premiere stuff in it.
                                      kannonbal:
                                      I've always used TIFF's and for some reason never really got used to using PNG's.
                                      I actually had to look and see if Premiere actually imported PNG's and Low and behold it does!! Whether it will import them as 'Numbered Stills' (See the revised tut) is another matter.
                                      As for the "dreaded moire" well that's the next bit I've got to do in the tut!
                                      Here's it quickly:
                                      Select the sequence
                                      From the menu select CLIP/VIDEO OPTIONS/FIELD OPTIONS
                                      Select 'Flicker Removal'
                                      Repeat for every Sequence (Very tedious)
                                      Drag into the time line and export.
                                      EDIT:
                                      Final tutorial linked here (from later post below)
                                      Paul Russam
                                      • Paul RussamP
                                        Paul Russam
                                        Done a bit more this lunch time and its now on a prototype SCF template.
                                        Edit:
                                        Opps sorry about the quality of the images in the PDF, I squidged them a bit too much.
                                        EDIT:
                                        Paul Russam
                                        • Paul RussamP
                                          Paul Russam
                                          Here's the first finished version:
                                          Tutorial
                                          Its a 1.2mb PDF
                                          I'm going to add more stuff in regard to adding titles, effects, editing etc. but not just yet.
                                          Please be critical and point out anything that's not clear, misspelt etc.
                                          Paul Russam
                                          • Paul RussamP
                                            Paul Russam
                                            Links fixed
                                            Paul Russam
