    Inverse Selection - where is it?
    32 Posts 15 Posters 45.8k Views 15 Watching
    • P
      PRSS
      Thanks Pilou
      I was very badly in need of this kind of a script.
      I want to hide all objects which are unselected.
      i.e. an equivalent of Max's Alt-Q which hides everything
      that is not selected.
      With best regards
      PRSS
        So easy now Selection : Right click/inverse + click "H" (if H is the shortcut of hide πŸ˜„
          this one? Right click/ menu
          invertselection.rb
          • jeff hammondJ
            hmm.. close but no cigar..
            there is a weird quirk with the script in that it introduces hidden geometry... it works ok with flat faces but doesn't help at all with curved ones..
            i'd like to be able to select a curved face and then invert the selection so everything else besides the face is selected... then i hit delete and all i'm left with is the curved face...
            with this script, i select the face (+ it's edges) and then activate the script.. when the selection is inverted, the hidden geometry shows up so when i delete, i'm only left with the outlining edges of the face... the workaround is to show hidden geometry from the beginning and make sure to select all of that stuff prior to running the script... then, it will work as i'd like but that's a bigger hassle then my previous work around..
            i'd like something to work exactly opposite of the normal select then delete where i can select a face with one click and delete it with one key.. easy ... i'd like to be able to select that same face and Save it with three moves (select, invert selction, delete).. if i have to double click the face in order to get the edges in the initial selection, that would be fine too..
            thanks for the help so far..
              I wrote 'invert selection' almost 2 years ago... What would you like it to do differently - exactly ?
              • jeff hammondJ
                thanks for the response TIG .. and any further assistance you may be able to add..
                i'm not sure if this little video clip is going to make my wishes clear or further compound the confusion but i'll give it a shot :)...
                you'll notice my hi tech number system in the lower left corner of the video.. the only operation you won't see me doing is pushing the delete key on my keyboard..
                1. selecting the surface and deleting it.. this is exactly opposite of what i'd like to be able to do which is select the surface and delete everything else (ie - select, invert, delete)
                2. trying to do just that with invertselection.rb... selecting only the face then inverting and deleting
                3. double clicking the surface in order to get the edges as well then inverting and deleting... this way would be fine as well except the hidden geometry comes into play upon the inversion which causes the surface to delete.
                4. in order for the face to remain, i have to show hidden geometry and select all of the hidden lines + the individual faces... then, when i invert and delete, i'm left with what i want .. however, the flow of doing it like this is not practical at all (especially when considering the more complex forms that i really want this script for)
                does this make any sense? if so, is it possible to tweak the script?
                thanks,
                jeff
                invert.mov.zip
                  You want this in one click?
                  • jeff hammondJ
                    no, not exactly and i think i'm confusing things by bringing 'delete' into the conversation..
                    what i want is an exact interpretation on the term 'inverse selection'... if i have some lines and faces selected, i'd like to be able to switch those to unselected and everything else selected...
                    the downfall of the script (imo) is that it introduces hidden geometry even if that option is off..
                    a perfect example of what i'm talking about can be seen on the cylinder that you've posted above..
                    draw the cylinder and make sure hidden geometry is turned off (as in -- sketchup -> view -> Hidden Geometry... it should be turned off so that the outside face appears smooth with no dotted lines running down it)...
                    now select all.. everything that is visible highlights.. by my logic, running the inverse select script at this point should deselect everything but it doesn't... everything visible deselects but now the hidden geometry shows up and is highlighted..
                    try it out.. see what i mean?
                    jeff
                    • GaieusG
                      I understand your problem, Jeff - and also I'd say the script is working "logically" since those softened (or hidden) edges were not selected until you ran the script so now they got selected.
                      Also I understand that you wish the script didn't work this way. Maybe TIG can tweak it a bit...
                      • jeff hammondJ
                        ok, cool.. i'm glad i'm getting my point across now.. i admit, i'm no wordsmith. πŸ™‚
                        the thing about what's logical or not is confusing because sketchup deals with it two different ways.. if i use edit -> select all (⌘A) or the select tool's window to encompass everything, then the hidden lines remain hidden and unselected (unless i have hidden geometry turned on)... if i use a triple click, then it includes everything including the hidden geometry...
                        i'm basing mine off the first choice but the other one makes just as much sense to me.. i just hope both situations are easy to deal with in ruby language (which i know Absolutely zero about)
                        • GaieusG
                          Ah yes, triple select always selects hidden geometry as well. I haven't figured out its logic in this but there may be one.
                          However I'm a total non-programmer so I can only use scripts. πŸ˜„
                            Now I see...
                            Here v1.1 - it works the same as before, BUT if the selection includes faces then it now assumes you want to include those faces' edges in the selection (visible/hidden/smoothed) even if you haven't explicitly picked any edges: then when it inverts the selection (and say you delete the now selected stuff) any previously selected faces AND their edges are retained...
                            Feedback please...
                            Gaieus - you might want to move this to the Ruby realms...
                            invertselection.rb
                              works fine when you delete
                              but when you hide seems curious result πŸ˜‰
                              (hidden geometry was enable for select facett then disable after selection and only 2 facets were selected)
                              Edited : all works fine, it was only result when you click on the selected facetts! πŸ‘
                              • GaieusG
                                @tig said:
                                ...Gaieus - you might want to move this to the Ruby realms...
                                Yeah, it makes sense - "done".
                                Thanks for the update, TIG! πŸ‘
                                • jeff hammondJ
                                  @tig said:
                                  Here v1.1
                                  wow TIG.. you_are_the_man
                                  thank you!
                                  • P
                                    pvbuero
                                    @ TIG,
                                    that's just fantastic what you're doing here.
                                    I face a problem an two minutes later it's been solved thanks to your script. Great πŸ˜„
                                      @pvbuero said:
                                      two minutes later
                                      ...and two years later there is a reply... πŸ˜†
                                        Jim
                                        Curious, has the selection behavior of hidden geom changed in recent versions?
                                          What/how do you mean?
                                            Jim
                                            Just my mind being illogical - it makes sense that hidden geoms are included when inverting the selection.
                                            It always feels like hidden geoms should not be included in the active_entities collection.
