    In Development: Subdivide and Smooth
    262 Posts 65 Posters 101.5k Views 65 Watching
    • jujuJ
      juju
      Looks sweet, when is it be due in the wild?
      • soloS
        The prophecy is fulfilled.....the gods of SU predicted this would happen one day.
        • spenceS
          spence
          Now that is cool, nice work!
          Spence
            remus
            that looks wicked, i can think of a thousand things i would use it for 😍
              dylan
              Nice looking ruby, this could open up many possibilities 👍
              http://dmdarchitecture.co.uk/
              • boofredlayB
                boofredlay
                This looks great. Would you be able to control the amount of extra polygons created? The examples seem to go very high poly.
                • W
                  Whaat
                  The examples shown are done with two smoothing iterations. One iteration may be adequate in many cases.
                  • FletchF
                    Fletch
                    wowwwww Whaat... you are incredible! 😲
                    can it reduce the polygon count of a hi-poly mesh (work in reverse) too?
                    Fletch
                    • K
                      kwistenbiebel
                      I completely missed this one....
                      In the example, the mesh is really clean with some nice triangulation.
                      This is unbelievable. I WANT this 😄
                        Take a look to the freeTopMod about this subject!
                        it import and export obj format
                        Import Su Objects are possible in OBJ Format with this sort of Plugin
                        Have fun with it! ☀
                        Gallery
                        • K
                          kwistenbiebel
                          I don't see the relevance here....Topmod isn't really a subdivision tool right?
                          Or am I missing something?....
                          • W
                            Whaat
                            I would like to show what this plugin will be capable of. Problem is, I have no idea what to model. Can anyone give me some ideas about what to try modeling with this plugin?
                            Think of something that simply isn't possible with the current SketchUp tools. I want to test the capabilities of the code.
                              Jim
                              Can it do something simple, and often requested: round the corners of a box?
                                Jim
                                It seems to me that this technique was probably developed not for modeling, but for rendering. It allows the modeling program (game engine) to keep a simple, low-poly model in the software for doing the complex calculations, and allow a hardware renderer (graphics card) to do the subdivision and display. The result being a faster overall application.
                                Of course, I could be way off. It's still way cool!
                                • K
                                  krash88
                                  Hi all. First of all, I work for a company that builds furniture and I do the digital samples in SU. Searching for this type of script is what brought me to these forums and it looks amazing. Our customers are constantly raising the level of detail that they want to see in my images but the limitations of SU make it time-consuming to do so. I have attached a SU6 file of a pillow that I modeled quite a while back and it's quite ugly. If you could, try your script on it and see if it helps. If I could model low poly things like this and subdivide and smooth them, it would save a tremendous amount of time.
                                  I have also attached images of both the old pillow and the beginnings of my new one. Connecting all of the lines gives me a headache. Being able to use your script would be great!
                                  PS.
                                  Is it possible to set a threshold angle with your script in order to keep certain edges, beyond a given angle, sharp?
                                  Old pillow
                                  http://www.mediafire.com/download.php?4k0gm9lc9jn
                                    hehe
                                    Topmod is the prog who has the big largest collection tools of subdivision! ☀
                                    it's for that I put it here 😉
                                    • T
                                      tomasz
                                      Whaat,
                                      I was thinking about your plugin.. and I have an idea. Could it keep the original low poly geometry with some default transparent material .. and work similar way to FFD.
                                      When you modify original geometry within group script would give you a chance to update hi-poly one. Like in Bledner - you can see both - low and high-poly mesh.
                                      We could even assign weights to .. edges?
                                      Just a thought.
                                      Tomasz
                                      • W
                                        Whaat
                                        Whaat,
                                        The ultimate goal is low poly proxy modeling like you have suggested. I believe it can be done but will not be easy. I will be looking at FFD for ideas about how to do it. I am searching for papers about how to implement it but have not found any yet.
                                        BTW, creased edges have already been implemented.
                                        • W
                                          Whaat
                                          It is not suited very well to this purpose although it could be done if the box was modeled a certain way.
                                          • K
                                            kwistenbiebel
                                            Whaat, I can think of numerous occasions I can use your script...
                                            For example: 'Makehumans', the open source human figure maker, produces low-poly models, which could definitely use some subdividion before using them in sketchup for rendering.
                                            When you look at the following rendering I made, you can see that subdivision is no luxury here:
                                            (by the way, you can find makehuman at this link: http://www.dedalo-3d.com/ )
                                            http://i140.photobucket.com/albums/r3/kwistenbiebel1/28-weeks-later-2.jpg
                                            • 13
                                            • 14
                                            • 1 / 14
