    In Development: Subdivide and Smooth
    262 Posts 65 Posters 64.0k Views 65 Watching
      Simply great!
      Lately a few of you guys have come up with some really complex and amazing stuff (like Didier's spray script, Adam's light script, Chris' free form script... now the new Kerky is here...)
      What's all this? Some kind of late Christmas? 😄
      • jujuJ Offline
        juju
        Looks sweet, when is it be due in the wild?
        • soloS Offline
          The prophecy is fulfilled.....the gods of SU predicted this would happen one day.
          • spenceS Offline
            spence
            Now that is cool, nice work!
            Spence
              remus
              that looks wicked, i can think of a thousand things i would use it for 😍
                dylan
                Nice looking ruby, this could open up many possibilities 👍
                http://dmdarchitecture.co.uk/
                • boofredlayB Offline
                  boofredlay
                  This looks great. Would you be able to control the amount of extra polygons created? The examples seem to go very high poly.
                  • W Offline
                    Whaat
                    The examples shown are done with two smoothing iterations. One iteration may be adequate in many cases.
                    • FletchF Offline
                      Fletch
                      wowwwww Whaat... you are incredible! 😲
                      can it reduce the polygon count of a hi-poly mesh (work in reverse) too?
                      Fletch
                        kwistenbiebel
                        I completely missed this one....
                        In the example, the mesh is really clean with some nice triangulation.
                        This is unbelievable. I WANT this 😄
                          Take a look to the freeTopMod about this subject!
                          it import and export obj format
                          Import Su Objects are possible in OBJ Format with this sort of Plugin
                          Have fun with it! ☀
                          Gallery
                            kwistenbiebel
                            I don't see the relevance here....Topmod isn't really a subdivision tool right?
                            Or am I missing something?....
                            • W Offline
                              Whaat
                              I would like to show what this plugin will be capable of. Problem is, I have no idea what to model. Can anyone give me some ideas about what to try modeling with this plugin?
                              Think of something that simply isn't possible with the current SketchUp tools. I want to test the capabilities of the code.
                                Jim
                                Can it do something simple, and often requested: round the corners of a box?
                                  Jim
                                  It seems to me that this technique was probably developed not for modeling, but for rendering. It allows the modeling program (game engine) to keep a simple, low-poly model in the software for doing the complex calculations, and allow a hardware renderer (graphics card) to do the subdivision and display. The result being a faster overall application.
                                  Of course, I could be way off. It's still way cool!
                                    krash88
                                    Hi all. First of all, I work for a company that builds furniture and I do the digital samples in SU. Searching for this type of script is what brought me to these forums and it looks amazing. Our customers are constantly raising the level of detail that they want to see in my images but the limitations of SU make it time-consuming to do so. I have attached a SU6 file of a pillow that I modeled quite a while back and it's quite ugly. If you could, try your script on it and see if it helps. If I could model low poly things like this and subdivide and smooth them, it would save a tremendous amount of time.
                                    I have also attached images of both the old pillow and the beginnings of my new one. Connecting all of the lines gives me a headache. Being able to use your script would be great!
                                    PS.
                                    Is it possible to set a threshold angle with your script in order to keep certain edges, beyond a given angle, sharp?
                                    Old pillow
                                    http://www.mediafire.com/download.php?4k0gm9lc9jn
                                      hehe
                                      Topmod is the prog who has the big largest collection tools of subdivision! ☀
                                      it's for that I put it here 😉
                                        tomasz
                                        Whaat,
                                        I was thinking about your plugin.. and I have an idea. Could it keep the original low poly geometry with some default transparent material .. and work similar way to FFD.
                                        When you modify original geometry within group script would give you a chance to update hi-poly one. Like in Bledner - you can see both - low and high-poly mesh.
                                        We could even assign weights to .. edges?
                                        Just a thought.
                                        Tomasz
                                        • W Offline
                                          Whaat
                                          Whaat,
                                          The ultimate goal is low poly proxy modeling like you have suggested. I believe it can be done but will not be easy. I will be looking at FFD for ideas about how to do it. I am searching for papers about how to implement it but have not found any yet.
                                          BTW, creased edges have already been implemented.
                                          • W Offline
                                            Whaat
                                            It is not suited very well to this purpose although it could be done if the box was modeled a certain way.
                                            • 13
                                            • 14
                                            • 1 / 14
