    [Obsolete] Component Spray Tool
    88 Posts 32 Posters 26.0k Views 32 Watching
    • Didier BurD Offline
      Didier Bur
      Hi CadFather,
      i think I've found what's wrong. It is bug-like but not really.
      Watch the "Layer" list and select a layer, don't let this field blank the first time you use the script.
      Am I right ?
      DB
        JAP
        Really nice tool, have used already quite a lot, very handy. Thanx Didier!
        • CadFatherC Offline
          CadFather
          thanks for looking into it Didier - you are right, it works very well now and wow, really a must have tool, thanks!
          so now i also know the intruding 2d bryce man in the 3d template has been drawn on 2 different layers!
            marne
            Incredible!
            I can't believe that this for free, you know that you gave away a "super-randor.rb" to us?
            Thank you very much for the hours(?) you were spending for the devolpment. I agree with CadFather: A must have.
            Thank you.
              Didier Bur
              Call me stupid, but what's a "super-randor.rb" ???
              DB
                CadFather
                it's a smustard plugin to randomise rotation and scale of selected objects by TBD
                  gorec
                  At me problem as well as at CadFather. Second click does not work.
                  I so did not understand that it is there needed to do with layers.
                    CadFather
                    in the dialog box there is a layer field which has to be chosen
                      marne
                      Thanks CadFather. It's all said πŸ˜„
                        rv1974
                        Hi Didier!
                        May be it was discussed earlier ..
                        1.There are 2 bugs: the plug-in limits drop-down list of components (for example 290 in model is reduced to 10 in dialog).
                        2.drop-down list is not stable: drop-down list of components is visible only if down arrow
                        is continually pressed.
                        Thanks for attention.
                          dmytty
                          @didier bur said:
                          Hi all,
                          Here is the new toy.
                          The last file is for french users only.
                          Enjoy πŸ˜„
                          How about including the ability to use a layer as a mask for including/excluding selected areas for component placement? Or how about being able to select a material type to include/exclude? Thus, if I had a street layout on a layer, I could click on 'Streets' layer and use it as an exclude mask for vegetation. Or I could click on a 'Soils' layer and 'include' this for component placement. The material option would allow me to select a material named 'dirt' as receiving all vegetation components.
                            Didier Bur
                            Doable. It's on the wish_list πŸ˜‰
                            Ruby API is guilty here...
                            DB
                            • jujuJ Offline
                              juju
                              @rv1974 said:
                              Hi Didier!
                              For the some or other reason the grass component I want isn't showing up in the drop-down list for components to spray. I've renamed the component so the name starts with a "#" as well as with a "01" in an attempt to get it to surface to the top of the list, but it still isn't showing up.
                              Does anybody have any idea how to get components onto the list that isn't showing up?
                              • jujuJ Offline
                                juju
                                OK, just tried the tool in a blank skippy. If you have a sky dome the spray tool doesn't work as expected - stuff ends up on top of the sky dome.
                                Didier, is it possible for you to sort this out?
                                  remus
                                  Couldnt you just spray the components and then place the sky dome?
                                  • jujuJ Offline
                                    juju
                                    I've moved the surface on which I want to spray above the sky dome, but it is still not working as expected.
                                    The surface is in a group, the group is active and I am able to select the surface and make changes to it. The spray tool keeps on returning an error about there not being a surface onto which to spray (not so, there is) tried up to 3000 tries.
                                    Still trying to get the component of choice onto the list to pick from (which component to spray).
                                    I'm working through the manual again to see if there is anything I missed.
                                      Didier Bur
                                      Oh oh,
                                      It seems that I have missed some particular situations (sky dome).
                                      I have totweak the script, and implement the layer mask feature.
                                      Next release coming...today.
                                      @Juju: you didn't miss anything... me yes.
                                      DB
                                      • jujuJ Offline
                                        juju
                                        Merci le bureau principal. Vous Γͺtes l'homme !
                                        (Thank you master Bur. You are the man!) - thanks to Babelfish translation.
                                        • jujuJ Offline
                                          juju
                                          @didier bur said:
                                          Oh oh,
                                          Didier, any news on this?
                                          +++ EDIT +++
                                          No bother, found the updated script. THANKS!
                                            Didier Bur
                                            Hi Juju,
                                            Did you d/l last version from 04.11.08 ? Perhaps you missed it.
                                            (2nd post of page 1 of this thread).
                                            I thought it would work πŸ˜’
                                            DB
                                            • 4 / 5
