    [Obsolete] Component Spray Tool
    88 Posts 32 Posters 31.5k Views 32 Watching
    • CadFatherC Offline
      CadFather
      well there's no skp really - all i did was put a rectangular ground plane, and then tried the spray on it. also tried on a small sandbox mesh.
      i tried again after posting yesterday and got the spray by point to work. the others though, will recognise the first click (centre of shape) but not the second so that i am in a sort of loop and the shape does not set.
      i noticed at times if i drew the radius (second click), way beyond the mesh a message would pop up warning me that a huge number of comps would be sprayed, when i reduced the radius to be inside the boundaries of the mesh, nothing happened..
      i will keep lookng into it - i seem to be the only one with this
      by the way great ruby, even by point it is great.
        kobus
        nice tool ! respect.
        you should be interested in the future. you will spend the rest of your life there
        • Didier BurD Offline
          Didier Bur
          Hi CadFather,
          i think I've found what's wrong. It is bug-like but not really.
          Watch the "Layer" list and select a layer, don't let this field blank the first time you use the script.
          Am I right ?
          DB
            JAP
            Really nice tool, have used already quite a lot, very handy. Thanx Didier!
              CadFather
              thanks for looking into it Didier - you are right, it works very well now and wow, really a must have tool, thanks!
              so now i also know the intruding 2d bryce man in the 3d template has been drawn on 2 different layers!
                marne
                Incredible!
                I can't believe that this for free, you know that you gave away a "super-randor.rb" to us?
                Thank you very much for the hours(?) you were spending for the devolpment. I agree with CadFather: A must have.
                Thank you.
                  Didier Bur
                  Call me stupid, but what's a "super-randor.rb" ???
                  DB
                    CadFather
                    it's a smustard plugin to randomise rotation and scale of selected objects by TBD
                      gorec
                      At me problem as well as at CadFather. Second click does not work.
                      I so did not understand that it is there needed to do with layers.
                        CadFather
                        in the dialog box there is a layer field which has to be chosen
                          marne
                          Thanks CadFather. It's all said 😄
                            rv1974
                            Hi Didier!
                            May be it was discussed earlier ..
                            1.There are 2 bugs: the plug-in limits drop-down list of components (for example 290 in model is reduced to 10 in dialog).
                            2.drop-down list is not stable: drop-down list of components is visible only if down arrow
                            is continually pressed.
                            Thanks for attention.
                              dmytty
                              @didier bur said:
                              Hi all,
                              Here is the new toy.
                              The last file is for french users only.
                              Enjoy 😄
                              How about including the ability to use a layer as a mask for including/excluding selected areas for component placement? Or how about being able to select a material type to include/exclude? Thus, if I had a street layout on a layer, I could click on 'Streets' layer and use it as an exclude mask for vegetation. Or I could click on a 'Soils' layer and 'include' this for component placement. The material option would allow me to select a material named 'dirt' as receiving all vegetation components.
                                Didier Bur
                                Doable. It's on the wish_list 😉
                                Ruby API is guilty here...
                                DB
                                • jujuJ Offline
                                  juju
                                  @rv1974 said:
                                  Hi Didier!
                                  For the some or other reason the grass component I want isn't showing up in the drop-down list for components to spray. I've renamed the component so the name starts with a "#" as well as with a "01" in an attempt to get it to surface to the top of the list, but it still isn't showing up.
                                  Does anybody have any idea how to get components onto the list that isn't showing up?
                                  • jujuJ Offline
                                    juju
                                    OK, just tried the tool in a blank skippy. If you have a sky dome the spray tool doesn't work as expected - stuff ends up on top of the sky dome.
                                    Didier, is it possible for you to sort this out?
                                      remus
                                      Couldnt you just spray the components and then place the sky dome?
                                      • jujuJ Offline
                                        juju
                                        I've moved the surface on which I want to spray above the sky dome, but it is still not working as expected.
                                        The surface is in a group, the group is active and I am able to select the surface and make changes to it. The spray tool keeps on returning an error about there not being a surface onto which to spray (not so, there is) tried up to 3000 tries.
                                        Still trying to get the component of choice onto the list to pick from (which component to spray).
                                        I'm working through the manual again to see if there is anything I missed.
                                          Didier Bur
                                          Oh oh,
                                          It seems that I have missed some particular situations (sky dome).
                                          I have totweak the script, and implement the layer mask feature.
                                          Next release coming...today.
                                          @Juju: you didn't miss anything... me yes.
                                          DB
                                          • jujuJ Offline
                                            juju
                                            Merci le bureau principal. Vous êtes l'homme !
                                            (Thank you master Bur. You are the man!) - thanks to Babelfish translation.
                                            • 1 / 5
