    [Obsolete] Component Spray Tool
    88 Posts 32 Posters 32.7k Views 32 Watching
    • Didier BurD
      Didier Bur
      Hi CadFather,
      Please post an example SKP so I can see if the problem is script-related or not.
      Regards,
      DB
      • CadFatherC
        CadFather
        well there's no skp really - all i did was put a rectangular ground plane, and then tried the spray on it. also tried on a small sandbox mesh.
        i tried again after posting yesterday and got the spray by point to work. the others though, will recognise the first click (centre of shape) but not the second so that i am in a sort of loop and the shape does not set.
        i noticed at times if i drew the radius (second click), way beyond the mesh a message would pop up warning me that a huge number of comps would be sprayed, when i reduced the radius to be inside the boundaries of the mesh, nothing happened..
        i will keep lookng into it - i seem to be the only one with this
        by the way great ruby, even by point it is great.
        • K
          kobus
          nice tool ! respect.
          you should be interested in the future. you will spend the rest of your life there
          • Didier BurD
            Didier Bur
            Hi CadFather,
            i think I've found what's wrong. It is bug-like but not really.
            Watch the "Layer" list and select a layer, don't let this field blank the first time you use the script.
            Am I right ?
            DB
              JAP
              Really nice tool, have used already quite a lot, very handy. Thanx Didier!
              • CadFatherC
                CadFather
                thanks for looking into it Didier - you are right, it works very well now and wow, really a must have tool, thanks!
                so now i also know the intruding 2d bryce man in the 3d template has been drawn on 2 different layers!
                  marne
                  Incredible!
                  I can't believe that this for free, you know that you gave away a "super-randor.rb" to us?
                  Thank you very much for the hours(?) you were spending for the devolpment. I agree with CadFather: A must have.
                  Thank you.
                  • Didier BurD
                    Didier Bur
                    Call me stupid, but what's a "super-randor.rb" ???
                    DB
                    • CadFatherC
                      CadFather
                      it's a smustard plugin to randomise rotation and scale of selected objects by TBD
                      • G
                        gorec
                        At me problem as well as at CadFather. Second click does not work.
                        I so did not understand that it is there needed to do with layers.
                        • CadFatherC
                          CadFather
                          in the dialog box there is a layer field which has to be chosen
                            marne
                            Thanks CadFather. It's all said πŸ˜„
                              rv1974
                              Hi Didier!
                              May be it was discussed earlier ..
                              1.There are 2 bugs: the plug-in limits drop-down list of components (for example 290 in model is reduced to 10 in dialog).
                              2.drop-down list is not stable: drop-down list of components is visible only if down arrow
                              is continually pressed.
                              Thanks for attention.
                                dmytty
                                @didier bur said:
                                Hi all,
                                Here is the new toy.
                                The last file is for french users only.
                                Enjoy πŸ˜„
                                How about including the ability to use a layer as a mask for including/excluding selected areas for component placement? Or how about being able to select a material type to include/exclude? Thus, if I had a street layout on a layer, I could click on 'Streets' layer and use it as an exclude mask for vegetation. Or I could click on a 'Soils' layer and 'include' this for component placement. The material option would allow me to select a material named 'dirt' as receiving all vegetation components.
                                • Didier BurD
                                  Didier Bur
                                  Doable. It's on the wish_list πŸ˜‰
                                  Ruby API is guilty here...
                                  DB
                                  • jujuJ
                                    juju
                                    @rv1974 said:
                                    Hi Didier!
                                    For the some or other reason the grass component I want isn't showing up in the drop-down list for components to spray. I've renamed the component so the name starts with a "#" as well as with a "01" in an attempt to get it to surface to the top of the list, but it still isn't showing up.
                                    Does anybody have any idea how to get components onto the list that isn't showing up?
                                    • jujuJ
                                      juju
                                      OK, just tried the tool in a blank skippy. If you have a sky dome the spray tool doesn't work as expected - stuff ends up on top of the sky dome.
                                      Didier, is it possible for you to sort this out?
                                        remus
                                        Couldnt you just spray the components and then place the sky dome?
                                        • jujuJ
                                          juju
                                          I've moved the surface on which I want to spray above the sky dome, but it is still not working as expected.
                                          The surface is in a group, the group is active and I am able to select the surface and make changes to it. The spray tool keeps on returning an error about there not being a surface onto which to spray (not so, there is) tried up to 3000 tries.
                                          Still trying to get the component of choice onto the list to pick from (which component to spray).
                                          I'm working through the manual again to see if there is anything I missed.
                                          • Didier BurD
                                            Didier Bur
                                            Oh oh,
                                            It seems that I have missed some particular situations (sky dome).
                                            I have totweak the script, and implement the layer mask feature.
                                            Next release coming...today.
                                            @Juju: you didn't miss anything... me yes.
                                            DB
                                            • 1 / 5
