    [Obsolete] Component Spray Tool
    88 Posts 32 Posters 32.7k Views 32 Watching
      dmytty
      @didier bur said:
      Hi all,
      Here is the new toy.
      The last file is for french users only.
      Enjoy 😄
      How about including the ability to use a layer as a mask for including/excluding selected areas for component placement? Or how about being able to select a material type to include/exclude? Thus, if I had a street layout on a layer, I could click on 'Streets' layer and use it as an exclude mask for vegetation. Or I could click on a 'Soils' layer and 'include' this for component placement. The material option would allow me to select a material named 'dirt' as receiving all vegetation components.
      • Didier BurD
        Didier Bur
        Doable. It's on the wish_list 😉
        drop-down list of components is visible only if down arrow
        is continually pressed.
        Ruby API is guilty here...
        DB
        • jujuJ
          juju
          @rv1974 said:
          Hi Didier!
          May be it was discussed earlier ..
          1.There are 2 bugs: the plug-in limits drop-down list of components (for example 290 in model is reduced to 10 in dialog).
          2.drop-down list is not stable: drop-down list of components is visible only if down arrow
          Thanks for attention.
          For the some or other reason the grass component I want isn't showing up in the drop-down list for components to spray. I've renamed the component so the name starts with a "#" as well as with a "01" in an attempt to get it to surface to the top of the list, but it still isn't showing up.
          Does anybody have any idea how to get components onto the list that isn't showing up?
          • jujuJ
            juju
            OK, just tried the tool in a blank skippy. If you have a sky dome the spray tool doesn't work as expected - stuff ends up on top of the sky dome.
            Didier, is it possible for you to sort this out?
              remus
              Couldnt you just spray the components and then place the sky dome?
              • jujuJ
                juju
                I've moved the surface on which I want to spray above the sky dome, but it is still not working as expected.
                The surface is in a group, the group is active and I am able to select the surface and make changes to it. The spray tool keeps on returning an error about there not being a surface onto which to spray (not so, there is) tried up to 3000 tries.
                Still trying to get the component of choice onto the list to pick from (which component to spray).
                I'm working through the manual again to see if there is anything I missed.
                • Didier BurD
                  Didier Bur
                  Oh oh,
                  It seems that I have missed some particular situations (sky dome).
                  I have totweak the script, and implement the layer mask feature.
                  Next release coming...today.
                  @Juju: you didn't miss anything... me yes.
                  DB
                  • jujuJ
                    juju
                    Merci le bureau principal. Vous êtes l'homme !
                    (Thank you master Bur. You are the man!) - thanks to Babelfish translation.
                    • jujuJ
                      juju
                      @didier bur said:
                      Oh oh,
                      Didier, any news on this?
                      +++ EDIT +++
                      No bother, found the updated script. THANKS!
                      • Didier BurD
                        Didier Bur
                        Hi Juju,
                        Did you d/l last version from 04.11.08 ? Perhaps you missed it.
                        (2nd post of page 1 of this thread).
                        I thought it would work 😒
                        DB
                          a4chitect
                          missed that one too! eager to try it out, thanks didier!
                          • jujuJ
                            juju
                            @didier bur said:
                            Hi Juju,
                            +++ EDIT +++
                            Didier, thanks for the follow-up. Yup, found it shortly after posting the comment, thus I edited it as above.
                            I have not tried it again, will do so later on and report back (obviously) if I experience any difficulties.
                              Jorgensen
                              Any plans on creating a toolbar for this nice script ?
                              • Didier BurD
                                Didier Bur
                                Why not ? Nice idea.
                                DB
                                • E
                                  el.antuan
                                  I agree.
                                  "En las fiestas no te sientes jamás; puede sentarse a tu lado alguien que no te guste." Groucho Marx
                                  • majidM
                                    majid
                                    if i was MR GooGle , i would give a nice job to Didier!!! plz accept my special thanx
                                      Jorgensen
                                      Could it be possible to set % less than 5% ?
                                      1%
                                      5%
                                      Custom ?
                                      Jorgensen
                                      • StinkieS
                                        Stinkie
                                        That'll be € 20, mate. A copywriter needs to eat too. 💚
                                        As do the nice folks who write all them cool Ruby scripts. I don't have a problem with people selling their scripts through Smustard. I mean, most of them are pretty cheap - and they can sure add a lot to SU's functionality.
                                        Look at this way: if a lot of these cool, non-free scripts were incorporated in SU, SU's price would go up. At least now you can choose whether you want to spend more or not.
                                        • K
                                          kwistenbiebel
                                          Oh, I don't have a problem with commercial scripts either and Smustard is a good place to buy them.
                                          From time to time though, a plugin stands out from the rest and feels like it could be part of Sketchup itself.
                                          I can imagine that a native Sketchup plugin written in C++ (or whatever the code language they use) can be streamlined more than a ruby, which works 'on top' of sketchup.
                                          (difference in speed and performance?)
                                          • StinkieS
                                            Stinkie
                                            Good point. The first one, I mean. Dunno 'bout the second one. Mee stoopeed.
                                            • 2 / 5
