    [Plugin] HouseBuilder metric 1.2
    79 Posts 42 Posters 118.9k Views 42 Watching
    • John SayersJ
      John Sayers
      Thanks mate - I'd really appreciate that. It's the best Ruby script of all. 😄
      BTW - I'm still confused between Header Height and Door Height in the door script. Surely they are the same thing.
      cheers
        AcesHigh
        Didier, seeing you are from France, I have two questions:
        1- you did make the feet/inches version before the metric one????
        2 - the house builder tool is mostly useful to these woodframe houses which are most common in US/Canada. In France most houses use bricks, dont they?
        [AcesHigh]
          2 - the house builder tool is mostly useful to these wood-frame houses which are most common in US/Canada. In France most houses use bricks, don't they?
          The House Builder tool set was developed a couple of years ago by Steve Hurlbut in the US - it was in '&", BUT Didier metricated it more recently... It meant changing all of the timber sizes, dialogs and so on so it took a while.
          • Didier BurD
            Didier Bur
            TIG is right, and as I said at the top of this thread: "this must-have developed by Steve Hurlbutt (and me for the toolbar, estimates, metric versions)".
            That's why it has been developed in feets first.
            Yes and no, it depends where the house is: bricks in the North, natural stone almost everywhere, concrete and concrete blocks in suburban areas, wood in the south-west and in all mountainous areas.
            Regards,
            DB
              AcesHigh
              thanks.
              Living in Brazil, where woodframe is almost non-existant, I use only the roof function of it, since many roofs from brick/concrete houses are done with wood frame/trussers, whatever 😄
              [AcesHigh]
              • aadbuildA
                aadbuild
                Hi all, I have been following the thread with house builder and I am having problems loading house builder as well. I am using a P.C and I have dropped house builder in the plugins folder and when I start Sketchup I come up with the following message:
                No such file to load -- HouseBuilder/HouseBuilderTool.rbError Loading File HouseBuilder_extension.rb
                (eval):36:in `readlines': No such file or directory - C:/Program Files/Google/Sketchup 6/Plugins\HouseBuilder\housebuilder_sections.txt
                I have tried sevral variations but I have had no luck. Is there any one who could steer me in the right direction. I am looking forward to see what house builder can do. Your help will be much appreciated. 😄
                Every building designed can be affordable & buildable, to help we built PlusSpec; VDC & BIM for Sketchup
                https://www.plusspec.com
                • Didier BurD
                  Didier Bur
                  if you have correctly unzipped the package in your Plugins folder, there should'nt be any problem.
                  Check that you have:
                  • HouseBuilder_extension.rb in your Plugins folder
                  • a sub-folder named "HouseBuilder" with 2 other .rb files in it and a lot of png's and gif's as well. A .txt file is also there, with the wood sections listed in it.
                  Read the readme.txt file for further details.
                  DB
                    abumail
                    Dera Didier,
                    Your Script is very useful and funny,
                    I have a doubt about the timber (beam) on top of the windows and door.
                    If i put door or windows it's result vertical, Shouldn't be horizontal?
                    Thank you in advance for your kind attention,
                    Giovanni
                    • AnssiA
                      Anssi
                      Giovanni,
                      I think it is a matter of both local convention and structural strength. When I was taught about framing (half a zillion years ago) I was told to put the beam vertically. So from my point of view this should be correct.
                      Anssi
                      • Didier BurD
                        Didier Bur
                        I agree with Anssi.
                        But I want also say that it is NOT my script. The original was coded by S. Hurlbutt, I only tweaked it to metric units and parametric sections...
                        DB
                          dayakar78mac.com
                          @didier bur said:
                          Hi Didier,
                          I have unzipped HouseBuilder_metric_12.zip in the Plugins folder. The HouseBuilder_extension.rb and sub-folder "HouseBuilder" are there as described by you. When I launch SketchUp, I still get the following error.
                          "Error Loading File HouseBuilder_extension.rb private method split called for nil:NilClass"
                          Could you please advice me to resolve this issue.
                          I am using SketchUp Pro v6.0 on iMac, Mac os x 10.5.4.
                          Thanks,
                          Dayakar
                          Error Loading file
                          • Didier BurD
                            Didier Bur
                            I'm puzzled because the "split" method is called several dozens of times in the code so I can't localize exactly where there's something wrong at startup. Maybe it's a Mac issue. Do you have a file "housebuilder_sections.txt in the HouseBuilder folder ? I guess yes...
                            Give me some time to search...But take a look at the top of this thread, other people on Mac have the same issue as yours.
                            DB
                            • P
                              pav_3j
                              wow, thank you very much! this is awesome
                              pav
                              Just won the 'Who is Least Competitive Championships' where trying to win will make you lose. Trying to lose makes you win which makes you lose. Not trying at all makes you lose which makes you win which makes you lose.
                                dayakar78mac.com
                                @didier bur said:
                                Hi Didier,
                                Thank you for the response. Yes, I do have have housebuilder_sections.txt in the HouseBuilder subfolder. This script is very useful, I saw the demo of this script at http://sites.google.com/site/3dbasecamp2008/all-sessions-2008/maxing-out-your-productivity-with-ruby-scripts.
                                Regards,
                                Dayakar
                                • T
                                  thinkbuild
                                  Greetings to all.
                                  Didier, just a quick note - I just wanted you to know that I am also having the same issues with my mac.
                                  private method `split' called for nil:NilClass"
                                  Any ideas?
                                  I tried to look for the "offending line" in the script but I quickly became confused. Is it "HouseBuilder_extension.rb", (which is not scrambled)
                                  or "HouseBuilder.rb", or "HouseBuilderTool.rb" (both of which are scrambled)?
                                  Please advise. I'm sure many of us in the Mac community would be very appreciative if we could get this to work!
                                  cheers from Berlin,
                                  Jason
                                  • Didier BurD
                                    Didier Bur
                                    It is probably in "HouseBuilder_extension.rb" there.
                                    I suspect this line is the offending one:
                                    su_path = Sketchup.find_support_file("Sketchup.exe").split("Sketchup.exe")[0]
                                    because there's no exe files on Mac, and they are located elsewhere. So su_path variable is nil, and when the script tries to locate the txt sections files, the su_path is splitted starting from a nil value, which raises error. (hope i'm clear 😳 )
                                    I'll take a look at this asap, but I'm very busy these days... Here is my todo list, apart from corporate devs:
                                    Terrain reshaper
                                    Housebuilder for Mac
                                    Transformer keys positions
                                    Align tool -> copy option
                                    Extrudelinesalongpath (follow me for lines)
                                    SU2STL & Heightfield_gen : binary tests
                                    Instancing brush for compo spray
                                    SU2POV mat editor sliders
                                    DB
                                    • T
                                      thinkbuild
                                      bonjour didier ...
                                      ok, i will see what i can do to make it work. note i am a total non-programmer, but maybe i'll have some luck and you can strike it off your list! i'll report back when i know if i have any success or not 😉
                                      a bientôt!
                                      jason
                                      • T
                                        thinkbuild
                                        Cher Didier,
                                        Bonjour! Alors, here's the report: I can't find the line you are talking about in the script. Pas trouve! It must be in one of the two scrambled files. Je regrete! Please advise if there is another way I can help!
                                        best wishes from Berlin,
                                        Jason
                                        • H
                                          Hazza
                                          Is it possible to change this so that the wall (or whatever) you just created is undone in one go?
                                          See all of my SketchUp models here.
                                            MrPlanet
                                            Hi! i want to delete housebuilder from my computer but it says it is being used by another person when sketchup is closed,can someone tell me what's happening?,thanks
                                            I reject your reality and substitute my own.
                                            • 1 / 4
