    [Plugin] HouseBuilder metric 1.2
    79 Posts 42 Posters 117.9k Views 42 Watching
    • kmeadK Offline
      kmead
      I have run into a bit of a problem:
      Error Loading File HouseBuilder_extension.rb
      private method `split' called for nil:NilClass
      I run on Mac OSX so that may be some part of the issue. Is there something else I should have loaded?
      [kmead]
      I created Dilbertville, sorry about that...
        samtsham
        Same here:
        Also on a Mac, and can also not get many other scripts to display (see separate post in Ruby-board).
        Any other Mac-users lucky with this one? Thanks ...
        SAM from Vienna.
        [samtsham]
        • Didier BurD Offline
          Didier Bur
          I think it's a path problem. To locate the Housebuilder path on your system, it first tries to locate where SU is installed, then it goes to the plugins folder, then to the Housebuilder folder, to read the sections text file.
          su_path = Sketchup.find_support_file("Sketchup.exe").split("Sketchup.exe")[0]
          This is the offending line of the script, because I suppose there's no ".exe" file on a Mac, right ?
          Please tell me where SU is installed by default on a Mac system and I'll try to solve this issue.
          Regards,
          DB
          • H Offline
            Haggai
            I just wanted to now if there is in view the possility to do angle walls ( not only 90 degres)?
            I really like the ruby. it is very easy to use even my boy ten is builden an amazing house with it. I just see how everything is increasing so fast with all the rubys, that is why i am asking, maybe also curved walls?
            thank for all the work you are doing for the Sketchup Community I have been looking here and there for a while now and I appreciate all that has been done.
            Merci beaucoup
            [Haggai]
            • F Offline
              Francois
              @didier bur said:
              Regards,
              Didier,
              I also have the same error message with HB metric 1.2 (on a Mac). But if this can help, HB metric v1.1 is working correctly for me. So, normally, the path used for 1.1 should work with 1.2
              Otherwise, I think the default location for SU is /Applications/Google Sketchup 6/ and the name is SketchUp.app
              Regards
              • John SayersJ Offline
                John Sayers
                Didier - as I've said before Housebuilder is a great resource. 😄
                Unfortunately I have a problem with the new metric version. I work in both imperial and in metric depending on the client's format. I installed the metric and it works for metric, but won't work in imperial so I've uninstalled it and gone back to the imperial version because it did work in metric.
                Is it possible to have both in one program with a selection between the two systems??
                cheers
                  Didier Bur
                  Hi John,
                  I will rework the script when back from holidays 😛 !
                  Regards,
                  DB
                    John Sayers
                    Thanks mate - I'd really appreciate that. It's the best Ruby script of all. 😄
                    BTW - I'm still confused between Header Height and Door Height in the door script. Surely they are the same thing.
                    cheers
                      AcesHigh
                      Didier, seeing you are from France, I have two questions:
                      1- you did make the feet/inches version before the metric one????
                      2 - the house builder tool is mostly useful to these woodframe houses which are most common in US/Canada. In France most houses use bricks, dont they?
                      [AcesHigh]
                        2 - the house builder tool is mostly useful to these wood-frame houses which are most common in US/Canada. In France most houses use bricks, don't they?
                        The House Builder tool set was developed a couple of years ago by Steve Hurlbut in the US - it was in '&", BUT Didier metricated it more recently... It meant changing all of the timber sizes, dialogs and so on so it took a while.
                          Didier Bur
                          TIG is right, and as I said at the top of this thread: "this must-have developed by Steve Hurlbutt (and me for the toolbar, estimates, metric versions)".
                          That's why it has been developed in feets first.
                          Yes and no, it depends where the house is: bricks in the North, natural stone almost everywhere, concrete and concrete blocks in suburban areas, wood in the south-west and in all mountainous areas.
                          Regards,
                          DB
                            AcesHigh
                            thanks.
                            Living in Brazil, where woodframe is almost non-existant, I use only the roof function of it, since many roofs from brick/concrete houses are done with wood frame/trussers, whatever 😄
                            [AcesHigh]
                            • aadbuildA Offline
                              aadbuild
                              Hi all, I have been following the thread with house builder and I am having problems loading house builder as well. I am using a P.C and I have dropped house builder in the plugins folder and when I start Sketchup I come up with the following message:
                              No such file to load -- HouseBuilder/HouseBuilderTool.rbError Loading File HouseBuilder_extension.rb
                              (eval):36:in `readlines': No such file or directory - C:/Program Files/Google/Sketchup 6/Plugins\HouseBuilder\housebuilder_sections.txt
                              I have tried sevral variations but I have had no luck. Is there any one who could steer me in the right direction. I am looking forward to see what house builder can do. Your help will be much appreciated. 😄
                              Every building designed can be affordable & buildable, to help we built PlusSpec; VDC & BIM for Sketchup
                              https://www.plusspec.com
                                Didier Bur
                                if you have correctly unzipped the package in your Plugins folder, there should'nt be any problem.
                                Check that you have:
                                • HouseBuilder_extension.rb in your Plugins folder
                                • a sub-folder named "HouseBuilder" with 2 other .rb files in it and a lot of png's and gif's as well. A .txt file is also there, with the wood sections listed in it.
                                Read the readme.txt file for further details.
                                DB
                                  abumail
                                  Dera Didier,
                                  Your Script is very useful and funny,
                                  I have a doubt about the timber (beam) on top of the windows and door.
                                  If i put door or windows it's result vertical, Shouldn't be horizontal?
                                  Thank you in advance for your kind attention,
                                  Giovanni
                                  • AnssiA Offline
                                    Anssi
                                    Giovanni,
                                    I think it is a matter of both local convention and structural strength. When I was taught about framing (half a zillion years ago) I was told to put the beam vertically. So from my point of view this should be correct.
                                    Anssi
                                      Didier Bur
                                      I agree with Anssi.
                                      But I want also say that it is NOT my script. The original was coded by S. Hurlbutt, I only tweaked it to metric units and parametric sections...
                                      DB
                                        dayakar78mac.com
                                        @didier bur said:
                                        Hi Didier,
                                        I have unzipped HouseBuilder_metric_12.zip in the Plugins folder. The HouseBuilder_extension.rb and sub-folder "HouseBuilder" are there as described by you. When I launch SketchUp, I still get the following error.
                                        "Error Loading File HouseBuilder_extension.rb private method split called for nil:NilClass"
                                        Could you please advice me to resolve this issue.
                                        I am using SketchUp Pro v6.0 on iMac, Mac os x 10.5.4.
                                        Thanks,
                                        Dayakar
                                        Error Loading file
                                          Didier Bur
                                          I'm puzzled because the "split" method is called several dozens of times in the code so I can't localize exactly where there's something wrong at startup. Maybe it's a Mac issue. Do you have a file "housebuilder_sections.txt in the HouseBuilder folder ? I guess yes...
                                          Give me some time to search...But take a look at the top of this thread, other people on Mac have the same issue as yours.
                                          DB
                                            pav_3j
                                            wow, thank you very much! this is awesome
                                            pav
                                            Just won the 'Who is Least Competitive Championships' where trying to win will make you lose. Trying to lose makes you win which makes you lose. Not trying at all makes you lose which makes you win which makes you lose.
                                            • 1 / 4
