    Cutting_windows.rb
    28 Posts 7 Posters 7.1k Views 7 Watching
    • P
      plessis
      Didier,
      c'est pour moi la premiere fois que je visite ce Forum.
      Comment il faut faire ca, envoyer un example.
      • P
        plessis
        Chèr Didier,
        Jéspère que ca marche.
        hans
        test cutting_windows.rb.skp
        • Didier BurD
          Didier Bur
          Hans,
          It works. I suppose you didn't click on the first point again when defining the cutting outline.
          SKP with cutting component OK
          DB
          • P
            plessis
            Hello Didier,
            Thanks for your efforts,
            Alas, it doesn't work.
            I'm sure that I have selected with 5 clicks.
            This morning I have tried also the option "" ...by face "
            and ...by points. But both methods don,t work.
            After selecting one way or the other I have turned the component 90 degrees
            and placed it with the move tool in the wall.
            Nothing happends ???
            I have a lot of plugins but this is the only one with problems.
            Hans
            • Didier BurD
              Didier Bur
              Hi Plessis,
              Is it working with the file I've attached ❓
              If yes, this means you had a problem when making th component cut.
              If no, it is a Sketchup config problem or something independant of the script itself.
              Hope this helps,
              DB
              • P
                plessis
                hello Didier,
                Thanks,
                Even with the attached file I'm not successfull.
                Perhaps it is a SU config problem.
                I don't know how to solve that.
                Bad luck for me !
                In the future I have to cut first the holes
                and after that I can place the windows / doors.
                Such as I did it in the past
                Hans
                • P
                  plessis
                  Hello Didier,
                  I think I have found it.
                  When I " intersect with model "
                  and after that the selected face erase IT WORKS !
                  Hans
                  Ahh no !!! Not wih thick walls.!!!
                  • Didier BurD
                    Didier Bur
                    Plessis,
                    You mean you placed components on walls and these walls were groups ?
                    DB
                    • P
                      plessis
                      Didier,
                      The walls are no components or groups.
                      I was too enthusiastic.
                      It works not.
                      Hans
                      • Didier BurD
                        Didier Bur
                        Keep trying, there's absolutely NO reason it cannot work for you and it works for others.
                        DB
                          dylan
                          I seem to be having a problem myself with this Didier.
                          I am using your posted skp to test.
                          Using your window component included I right click, click the four corners in a clockwise direction then finish with a fifth click on the 1st point.
                          I get the 4 pink squares until I click outside the component on finishing.
                          If I double click and open the component, the axis is sat on the plane where the pink boxs were.
                          Placing the window on the wall does not cut.
                          Am I missing a step?
                          http://dmdarchitecture.co.uk/
                          • GaieusG
                            Didier, you can embed Flash during the post, can't you? (True it needs to already be somewhere on the net).
                            • Didier BurD
                              Didier Bur
                              Placing the window on the wall does not cut. Am I missing a step?
                              Yes. Once the component has been placed on the wall, you must "tell" SU where the window will be (in the width of the wall).
                              Right-click, select "window and wall / Cut wall from window".
                              Watch this little flash anim:
                              (sorry, SWF extension not allowed, so it is zipped)
                              [flash=654,438:3o0ia8b4]http://www.crai.archi.fr/RubyLibraryDepot/Ruby/cutting_windows_1.swf[/flash:3o0ia8b4]
                              cutting_windows_1.zip
                              DB
                              • GaieusG
                                The controls should be within the flash file. I can't open pure flash files here in my office but I1ll have a look at home.
                                Also I don't use Wink but Coen does so I'll let him know about this and he can give you some advice maybe.
                                • Didier BurD
                                  Didier Bur
                                  Sorry, I didn't noticed that 😳
                                  Let's see if it works.
                                  EDIT: I only see the wink logo when embedding that:
                                  ...flash=654,438]http://www.crai.archi.fr/RubyLibraryDepot/Ruby/cutting_windows_1.swf[/flash...
                                  DB
                                    Jorgensen
                                    Hi Didier
                                    I'm having some problems when I enter distance from inner face of wall.
                                    My wall is 400mm, and when I enter 230mm, it places the window 2300mm from the face - there seems to be some small bug here ? I know, I can just enter 23mm, then it's ok, but just wanted to let you know. Nice script 😄
                                    Jorgensen
                                    • Didier BurD
                                      Didier Bur
                                      YESSSS, you're the winner of the bug-hunt-down-contest !
                                      Will publish a patch asap,
                                      DB
                                      • P
                                        plessis
                                        Hello Didier,
                                        Thanks for your excellent flash.
                                        Now , it works very good. Just a little problem
                                        with entering the distance
                                        bye Hans
                                        • Didier BurD
                                          Didier Bur
                                          Yes, the distance glitch is fixed. Will upload the patch tomorrow on the depositary, but you can get it right now at my site.
                                          DB
                                          • jujuJ
                                            juju
                                            Didier, the link on your site for the cutting windows ruby is "error 404".
