    Cutting_windows.rb
    28 Posts 7 Posters 5.3k Views 7 Watching
      plessis
      j'ai installé cutting_windows.rb.
      Tous va comme il faut, ☀ je peux choisir "make me a cutting window by .....
      Mais quand je colle la fenêtre dans le mur elle ne coupe pas un trou.
      au secours au secours
      hans groenen 😡 ☀
      • AdamBA Offline
        AdamB
        You say it didn't make the hole in the wall, but did it do anything? ie Is it that it just didn't make a good cut?
        Adam
          plessis
          Hi Adam,
          Indeed, It didn't make a hole in the wall Nothing happends 😡
          Hans
          • Didier BurD Offline
            Didier Bur
            Bjr,
            Tu la colle bien sur la face extérieure du mur ?
            DB
              plessis
              bonjour Didier,
              J'epère je peux me faire comprendre.
              Oui, je colle bien sur la surface.
              Je l'ai essayé une dixaine fois avec des fenêtres du components en avec des fenêtres qui j'ai dessiné
              hans
                Didier Bur
                Hans,
                Send me a SKP example with a component that causes a problem, I'll check it
                DB
                  plessis
                  Didier,
                  c'est pour moi la premiere fois que je visite ce Forum.
                  Comment il faut faire ca, envoyer un example.
                    plessis
                    Chèr Didier,
                    Jéspère que ca marche.
                    hans
                    test cutting_windows.rb.skp
                      Didier Bur
                      Hans,
                      It works. I suppose you didn't click on the first point again when defining the cutting outline.
                      SKP with cutting component OK
                      DB
                        plessis
                        Hello Didier,
                        Thanks for your efforts,
                        Alas, it doesn't work.
                        I'm sure that I have selected with 5 clicks.
                        This morning I have tried also the option "" ...by face "
                        and ...by points. But both methods don,t work.
                        After selecting one way or the other I have turned the component 90 degrees
                        and placed it with the move tool in the wall.
                        Nothing happends ???
                        I have a lot of plugins but this is the only one with problems.
                        Hans
                          Didier Bur
                          Hi Plessis,
                          Is it working with the file I've attached ❓
                          If yes, this means you had a problem when making th component cut.
                          If no, it is a Sketchup config problem or something independant of the script itself.
                          Hope this helps,
                          DB
                            plessis
                            hello Didier,
                            Thanks,
                            Even with the attached file I'm not successfull.
                            Perhaps it is a SU config problem.
                            I don't know how to solve that.
                            Bad luck for me !
                            In the future I have to cut first the holes
                            and after that I can place the windows / doors.
                            Such as I did it in the past
                            Hans
                              plessis
                              Hello Didier,
                              I think I have found it.
                              When I " intersect with model "
                              and after that the selected face erase IT WORKS !
                              Hans
                              Ahh no !!! Not wih thick walls.!!!
                                Didier Bur
                                Plessis,
                                You mean you placed components on walls and these walls were groups ?
                                DB
                                  plessis
                                  Didier,
                                  The walls are no components or groups.
                                  I was too enthusiastic.
                                  It works not.
                                  Hans
                                    Didier Bur
                                    Keep trying, there's absolutely NO reason it cannot work for you and it works for others.
                                    DB
                                      dylan
                                      I seem to be having a problem myself with this Didier.
                                      I am using your posted skp to test.
                                      Using your window component included I right click, click the four corners in a clockwise direction then finish with a fifth click on the 1st point.
                                      I get the 4 pink squares until I click outside the component on finishing.
                                      If I double click and open the component, the axis is sat on the plane where the pink boxs were.
                                      Placing the window on the wall does not cut.
                                      Am I missing a step?
                                      http://dmdarchitecture.co.uk/
                                        Didier, you can embed Flash during the post, can't you? (True it needs to already be somewhere on the net).
                                          Didier Bur
                                          Placing the window on the wall does not cut. Am I missing a step?
                                          Yes. Once the component has been placed on the wall, you must "tell" SU where the window will be (in the width of the wall).
                                          Right-click, select "window and wall / Cut wall from window".
                                          Watch this little flash anim:
                                          (sorry, SWF extension not allowed, so it is zipped)
                                          [flash=654,438:3o0ia8b4]http://www.crai.archi.fr/RubyLibraryDepot/Ruby/cutting_windows_1.swf[/flash:3o0ia8b4]
                                          cutting_windows_1.zip
                                          DB
                                            The controls should be within the flash file. I can't open pure flash files here in my office but I1ll have a look at home.
                                            Also I don't use Wink but Coen does so I'll let him know about this and he can give you some advice maybe.
