    Cutting_windows.rb
    28 Posts 7 Posters 7.1k Views 7 Watching
    • P
      plessis
      Didier,
      The walls are no components or groups.
      I was too enthusiastic.
      It works not.
      Hans
      • Didier BurD
        Didier Bur
        Keep trying, there's absolutely NO reason it cannot work for you and it works for others.
        DB
          dylan
          I seem to be having a problem myself with this Didier.
          I am using your posted skp to test.
          Using your window component included I right click, click the four corners in a clockwise direction then finish with a fifth click on the 1st point.
          I get the 4 pink squares until I click outside the component on finishing.
          If I double click and open the component, the axis is sat on the plane where the pink boxs were.
          Placing the window on the wall does not cut.
          Am I missing a step?
          http://dmdarchitecture.co.uk/
          • GaieusG
            Didier, you can embed Flash during the post, can't you? (True it needs to already be somewhere on the net).
            • Didier BurD
              Didier Bur
              Placing the window on the wall does not cut. Am I missing a step?
              Yes. Once the component has been placed on the wall, you must "tell" SU where the window will be (in the width of the wall).
              Right-click, select "window and wall / Cut wall from window".
              Watch this little flash anim:
              (sorry, SWF extension not allowed, so it is zipped)
              [flash=654,438:3o0ia8b4]http://www.crai.archi.fr/RubyLibraryDepot/Ruby/cutting_windows_1.swf[/flash:3o0ia8b4]
              cutting_windows_1.zip
              DB
              • GaieusG
                The controls should be within the flash file. I can't open pure flash files here in my office but I1ll have a look at home.
                Also I don't use Wink but Coen does so I'll let him know about this and he can give you some advice maybe.
                • Didier BurD
                  Didier Bur
                  Sorry, I didn't noticed that 😳
                  Let's see if it works.
                  EDIT: I only see the wink logo when embedding that:
                  ...flash=654,438]http://www.crai.archi.fr/RubyLibraryDepot/Ruby/cutting_windows_1.swf[/flash...
                  DB
                    Jorgensen
                    Hi Didier
                    I'm having some problems when I enter distance from inner face of wall.
                    My wall is 400mm, and when I enter 230mm, it places the window 2300mm from the face - there seems to be some small bug here ? I know, I can just enter 23mm, then it's ok, but just wanted to let you know. Nice script πŸ˜„
                    Jorgensen
                    • Didier BurD
                      Didier Bur
                      YESSSS, you're the winner of the bug-hunt-down-contest !
                      Will publish a patch asap,
                      DB
                      • P
                        plessis
                        Hello Didier,
                        Thanks for your excellent flash.
                        Now , it works very good. Just a little problem
                        with entering the distance
                        bye Hans
                        • Didier BurD
                          Didier Bur
                          Yes, the distance glitch is fixed. Will upload the patch tomorrow on the depositary, but you can get it right now at my site.
                          DB
                          • jujuJ
                            juju
                            Didier, the link on your site for the cutting windows ruby is "error 404".
                            • Didier BurD
                              Didier Bur
                              No, I've just tried it, it is OK.
                              Go to metric Plugins, Architecture section, and then Cutting_Windows.zip.
                              Here is the direct link:
                              http://www.crai.archi.fr/RubyLibraryDepot/Ruby/EM/Cutting_Windows.zip
                              DB
                              • jujuJ
                                juju
                                Aah, thx for that, got the DL. Previously I went to your home page, selected "Newest Plugins" and selected the "Cutting Windows" (which still gives me that error referred to above).
                                • 2 / 2
