    Cutting_windows.rb
    28 Posts 7 Posters 6.5k Views 7 Watching
      plessis
      Hello Didier,
      I think I have found it.
      When I " intersect with model "
      and after that the selected face erase IT WORKS !
      Hans
      Ahh no !!! Not wih thick walls.!!!
      • Didier BurD Offline
        Didier Bur
        Plessis,
        You mean you placed components on walls and these walls were groups ?
        DB
          plessis
          Didier,
          The walls are no components or groups.
          I was too enthusiastic.
          It works not.
          Hans
            Didier Bur
            Keep trying, there's absolutely NO reason it cannot work for you and it works for others.
            DB
              dylan
              I seem to be having a problem myself with this Didier.
              I am using your posted skp to test.
              Using your window component included I right click, click the four corners in a clockwise direction then finish with a fifth click on the 1st point.
              I get the 4 pink squares until I click outside the component on finishing.
              If I double click and open the component, the axis is sat on the plane where the pink boxs were.
              Placing the window on the wall does not cut.
              Am I missing a step?
              http://dmdarchitecture.co.uk/
                Didier, you can embed Flash during the post, can't you? (True it needs to already be somewhere on the net).
                  Didier Bur
                  Placing the window on the wall does not cut. Am I missing a step?
                  Yes. Once the component has been placed on the wall, you must "tell" SU where the window will be (in the width of the wall).
                  Right-click, select "window and wall / Cut wall from window".
                  Watch this little flash anim:
                  (sorry, SWF extension not allowed, so it is zipped)
                  [flash=654,438:3o0ia8b4]http://www.crai.archi.fr/RubyLibraryDepot/Ruby/cutting_windows_1.swf[/flash:3o0ia8b4]
                  cutting_windows_1.zip
                  DB
                    The controls should be within the flash file. I can't open pure flash files here in my office but I1ll have a look at home.
                    Also I don't use Wink but Coen does so I'll let him know about this and he can give you some advice maybe.
                      Didier Bur
                      Sorry, I didn't noticed that 😳
                      Let's see if it works.
                      EDIT: I only see the wink logo when embedding that:
                      ...flash=654,438]http://www.crai.archi.fr/RubyLibraryDepot/Ruby/cutting_windows_1.swf[/flash...
                      DB
                        Jorgensen
                        Hi Didier
                        I'm having some problems when I enter distance from inner face of wall.
                        My wall is 400mm, and when I enter 230mm, it places the window 2300mm from the face - there seems to be some small bug here ? I know, I can just enter 23mm, then it's ok, but just wanted to let you know. Nice script πŸ˜„
                        Jorgensen
                          Didier Bur
                          YESSSS, you're the winner of the bug-hunt-down-contest !
                          Will publish a patch asap,
                          DB
                            plessis
                            Hello Didier,
                            Thanks for your excellent flash.
                            Now , it works very good. Just a little problem
                            with entering the distance
                            bye Hans
                              Didier Bur
                              Yes, the distance glitch is fixed. Will upload the patch tomorrow on the depositary, but you can get it right now at my site.
                              DB
                              • jujuJ Offline
                                juju
                                Didier, the link on your site for the cutting windows ruby is "error 404".
                                  Didier Bur
                                  No, I've just tried it, it is OK.
                                  Go to metric Plugins, Architecture section, and then Cutting_Windows.zip.
                                  Here is the direct link:
                                  http://www.crai.archi.fr/RubyLibraryDepot/Ruby/EM/Cutting_Windows.zip
                                  DB
                                  • jujuJ Offline
                                    juju
                                    Aah, thx for that, got the DL. Previously I went to your home page, selected "Newest Plugins" and selected the "Cutting Windows" (which still gives me that error referred to above).
                                    • 2 / 2
