    Cutting_windows.rb
    28 Posts 7 Posters 6.1k Views 7 Watching
    • Didier BurD Offline
      Didier Bur
      Bjr,
      quand je colle la fenêtre dans le mur
      Tu la colle bien sur la face extérieure du mur ?
      DB
        plessis
        bonjour Didier,
        J'epère je peux me faire comprendre.
        Oui, je colle bien sur la surface.
        Je l'ai essayé une dixaine fois avec des fenêtres du components en avec des fenêtres qui j'ai dessiné
        hans
          Didier Bur
          Hans,
          Send me a SKP example with a component that causes a problem, I'll check it
          DB
            plessis
            Didier,
            c'est pour moi la premiere fois que je visite ce Forum.
            Comment il faut faire ca, envoyer un example.
              plessis
              Chèr Didier,
              Jéspère que ca marche.
              hans
              test cutting_windows.rb.skp
                Didier Bur
                Hans,
                It works. I suppose you didn't click on the first point again when defining the cutting outline.
                SKP with cutting component OK
                DB
                  plessis
                  Hello Didier,
                  Thanks for your efforts,
                  Alas, it doesn't work.
                  I'm sure that I have selected with 5 clicks.
                  This morning I have tried also the option "" ...by face "
                  and ...by points. But both methods don,t work.
                  After selecting one way or the other I have turned the component 90 degrees
                  and placed it with the move tool in the wall.
                  Nothing happends ???
                  I have a lot of plugins but this is the only one with problems.
                  Hans
                    Didier Bur
                    Hi Plessis,
                    Is it working with the file I've attached ❓
                    If yes, this means you had a problem when making th component cut.
                    If no, it is a Sketchup config problem or something independant of the script itself.
                    Hope this helps,
                    DB
                      plessis
                      hello Didier,
                      Thanks,
                      Even with the attached file I'm not successfull.
                      Perhaps it is a SU config problem.
                      I don't know how to solve that.
                      Bad luck for me !
                      In the future I have to cut first the holes
                      and after that I can place the windows / doors.
                      Such as I did it in the past
                      Hans
                        plessis
                        Hello Didier,
                        I think I have found it.
                        When I " intersect with model "
                        and after that the selected face erase IT WORKS !
                        Hans
                        Ahh no !!! Not wih thick walls.!!!
                          Didier Bur
                          Plessis,
                          You mean you placed components on walls and these walls were groups ?
                          DB
                            plessis
                            Didier,
                            The walls are no components or groups.
                            I was too enthusiastic.
                            It works not.
                            Hans
                              Didier Bur
                              Keep trying, there's absolutely NO reason it cannot work for you and it works for others.
                              DB
                                dylan
                                I seem to be having a problem myself with this Didier.
                                I am using your posted skp to test.
                                Using your window component included I right click, click the four corners in a clockwise direction then finish with a fifth click on the 1st point.
                                I get the 4 pink squares until I click outside the component on finishing.
                                If I double click and open the component, the axis is sat on the plane where the pink boxs were.
                                Placing the window on the wall does not cut.
                                Am I missing a step?
                                http://dmdarchitecture.co.uk/
                                  Didier, you can embed Flash during the post, can't you? (True it needs to already be somewhere on the net).
                                    Didier Bur
                                    Placing the window on the wall does not cut. Am I missing a step?
                                    Yes. Once the component has been placed on the wall, you must "tell" SU where the window will be (in the width of the wall).
                                    Right-click, select "window and wall / Cut wall from window".
                                    Watch this little flash anim:
                                    (sorry, SWF extension not allowed, so it is zipped)
                                    [flash=654,438:3o0ia8b4]http://www.crai.archi.fr/RubyLibraryDepot/Ruby/cutting_windows_1.swf[/flash:3o0ia8b4]
                                    cutting_windows_1.zip
                                    DB
                                      The controls should be within the flash file. I can't open pure flash files here in my office but I1ll have a look at home.
                                      Also I don't use Wink but Coen does so I'll let him know about this and he can give you some advice maybe.
                                        Didier Bur
                                        Sorry, I didn't noticed that 😳
                                        Let's see if it works.
                                        EDIT: I only see the wink logo when embedding that:
                                        ...flash=654,438]http://www.crai.archi.fr/RubyLibraryDepot/Ruby/cutting_windows_1.swf[/flash...
                                        DB
                                          Jorgensen
                                          Hi Didier
                                          I'm having some problems when I enter distance from inner face of wall.
                                          My wall is 400mm, and when I enter 230mm, it places the window 2300mm from the face - there seems to be some small bug here ? I know, I can just enter 23mm, then it's ok, but just wanted to let you know. Nice script 😄
                                          Jorgensen
                                            Didier Bur
                                            YESSSS, you're the winner of the bug-hunt-down-contest !
                                            Will publish a patch asap,
                                            DB
