    Cutting_windows.rb
    28 Posts 7 Posters 6.6k Views 7 Watching
    • P
      plessis
      Hello Didier,
      Thanks for your efforts,
      Alas, it doesn't work.
      I'm sure that I have selected with 5 clicks.
      This morning I have tried also the option "" ...by face "
      and ...by points. But both methods don,t work.
      After selecting one way or the other I have turned the component 90 degrees
      and placed it with the move tool in the wall.
      Nothing happends ???
      I have a lot of plugins but this is the only one with problems.
      Hans
      • Didier BurD
        Didier Bur
        Hi Plessis,
        Is it working with the file I've attached ❓
        If yes, this means you had a problem when making th component cut.
        If no, it is a Sketchup config problem or something independant of the script itself.
        Hope this helps,
        DB
        • P
          plessis
          hello Didier,
          Thanks,
          Even with the attached file I'm not successfull.
          Perhaps it is a SU config problem.
          I don't know how to solve that.
          Bad luck for me !
          In the future I have to cut first the holes
          and after that I can place the windows / doors.
          Such as I did it in the past
          Hans
          • P
            plessis
            Hello Didier,
            I think I have found it.
            When I " intersect with model "
            and after that the selected face erase IT WORKS !
            Hans
            Ahh no !!! Not wih thick walls.!!!
            • Didier BurD
              Didier Bur
              Plessis,
              You mean you placed components on walls and these walls were groups ?
              DB
              • P
                plessis
                Didier,
                The walls are no components or groups.
                I was too enthusiastic.
                It works not.
                Hans
                • Didier BurD
                  Didier Bur
                  Keep trying, there's absolutely NO reason it cannot work for you and it works for others.
                  DB
                    dylan
                    I seem to be having a problem myself with this Didier.
                    I am using your posted skp to test.
                    Using your window component included I right click, click the four corners in a clockwise direction then finish with a fifth click on the 1st point.
                    I get the 4 pink squares until I click outside the component on finishing.
                    If I double click and open the component, the axis is sat on the plane where the pink boxs were.
                    Placing the window on the wall does not cut.
                    Am I missing a step?
                    http://dmdarchitecture.co.uk/
                    • GaieusG
                      Didier, you can embed Flash during the post, can't you? (True it needs to already be somewhere on the net).
                      • Didier BurD
                        Didier Bur
                        Placing the window on the wall does not cut. Am I missing a step?
                        Yes. Once the component has been placed on the wall, you must "tell" SU where the window will be (in the width of the wall).
                        Right-click, select "window and wall / Cut wall from window".
                        Watch this little flash anim:
                        (sorry, SWF extension not allowed, so it is zipped)
                        [flash=654,438:3o0ia8b4]http://www.crai.archi.fr/RubyLibraryDepot/Ruby/cutting_windows_1.swf[/flash:3o0ia8b4]
                        cutting_windows_1.zip
                        DB
                        • GaieusG
                          The controls should be within the flash file. I can't open pure flash files here in my office but I1ll have a look at home.
                          Also I don't use Wink but Coen does so I'll let him know about this and he can give you some advice maybe.
                          • Didier BurD
                            Didier Bur
                            Sorry, I didn't noticed that 😳
                            Let's see if it works.
                            EDIT: I only see the wink logo when embedding that:
                            ...flash=654,438]http://www.crai.archi.fr/RubyLibraryDepot/Ruby/cutting_windows_1.swf[/flash...
                            DB
                              Jorgensen
                              Hi Didier
                              I'm having some problems when I enter distance from inner face of wall.
                              My wall is 400mm, and when I enter 230mm, it places the window 2300mm from the face - there seems to be some small bug here ? I know, I can just enter 23mm, then it's ok, but just wanted to let you know. Nice script πŸ˜„
                              Jorgensen
                              • Didier BurD
                                Didier Bur
                                YESSSS, you're the winner of the bug-hunt-down-contest !
                                Will publish a patch asap,
                                DB
                                • P
                                  plessis
                                  Hello Didier,
                                  Thanks for your excellent flash.
                                  Now , it works very good. Just a little problem
                                  with entering the distance
                                  bye Hans
                                  • Didier BurD
                                    Didier Bur
                                    Yes, the distance glitch is fixed. Will upload the patch tomorrow on the depositary, but you can get it right now at my site.
                                    DB
                                    • jujuJ
                                      juju
                                      Didier, the link on your site for the cutting windows ruby is "error 404".
                                      • Didier BurD
                                        Didier Bur
                                        No, I've just tried it, it is OK.
                                        Go to metric Plugins, Architecture section, and then Cutting_Windows.zip.
                                        Here is the direct link:
                                        http://www.crai.archi.fr/RubyLibraryDepot/Ruby/EM/Cutting_Windows.zip
                                        DB
                                        • jujuJ
                                          juju
                                          Aah, thx for that, got the DL. Previously I went to your home page, selected "Newest Plugins" and selected the "Cutting Windows" (which still gives me that error referred to above).
