    Simple venetian blinds
    17 Posts 9 Posters 3.6k Views 9 Watching
      Remus, for something like this just remember to hide (Shift+Eraser) the edges that would form the seam line. Don't soften them. FWIW, I expect that the file size could be reduced even further without showing much in the model. If you notice, I quareted the sphere that makes up the little "toggle" on the end of the pull cord. Reducing the number of faces used to create that sphere would have helped a lot too.
        dylan
        Thanks guys, a very useful addition.
        http://dmdarchitecture.co.uk/
        • Wo3DanW
          Wo3Dan
          Remus, Dave R,
          Dave R, seamless?
          It was only yesterday (= last year!) that I read about your advice somewhere in another thread about putting components (parts) seamlessly together by also erasing the inner faces.
          Unfortunately now I can’t find it anymore.
          Something you forgot to do here. But still, your credit. Nice useful component approach, also to Remus, thanks.
            Very nice blinds Remus. I think those will come in handy.
            I couldn't help myself. Had to see what I could do to reduce the file size a bit. I could reduce it more but this was quick. I did remove the wood grain texture figuring the user can add that later in their project if desired. I didn't change the pull cord but did modify the others. I also added a center section without cords that can be easily adjusted for length to make the blinds fit as needed.
            blinds.skp
              @wo3dan said:
              Remus, Dave R,
              Dave R, seamless?
              Whatchoo talkin' 'bout, Willis? 😄
              Yeah, I did neglect to delete those faces as I should have done. I was fending off a 3 year old while I was working. I fixed it though.
              • GaieusG
                Oh, come on guys, everybody (should) know that trick:
                http://www.sketchucation.com/forums/scf/viewtopic.php?f=20&t=796
                (OK - we all know that it cannot be repeated as many times as needed)
                • Wo3DanW
                  Wo3Dan
                  @gaieus said:
                  Oh, come on guys, everybody (should) know that trick:.......
                  Gaieus, somewhere around Nov 18 some people didn’t seem to know ‘this trick’ and I bet you that his three year old still does not know. But not for long. 💚
                  You see, both of them are putting a perfect component together. This could be applied to similar components since SU does not handle parametric components.
                  And I know, it was just a minor thing to mention. So please forgive me this time, please!!! 😢
                  cheers, Wo3Dan
                    @wo3dan said:
                    Gaieus, somewhere around Nov 18 some people didn’t seem to know ‘this trick’ and I bet you that his three year old still does not know. But not for long. 💚 [/qoute]
                    You're not kidding! That kid is already using one of the PCs aas well as the iMac. He will be using SketchUp before too long. 😲 😉
                    cheers, Wo3Dan
                    No need, nothing to forgive. Your point was well taken. It should be a well known thing and I should not have omitted it. No worries.
                    Dave
                    • GaieusG
                      I was just joking, men, and adding a link there that way. I hope no-one misunderstood me.
                      • Wo3DanW
                        Wo3Dan
                        @dave r said:
                        No need, nothing to forgive. Your point was well taken. It should be a well known thing and I should not have omitted it. No worries...
                        Dave R, Gaieus,
                        No misunderstanding at this side, pure irony, so sorry for asking forgiveness 😲
                        btw, where do I put a request for a ruby plug-inn 💭 that might be useful to some/many?
                        In Ruby-discussions maybe? It will most likely be a very simple ruby (and this is no joke).
                        My request will come with a simple model to show the workaround so fare.
                        cheers,
                        Wo3Dan
                        • boofredlayB
                          boofredlay
                          You have it right, place your request for a ruby in the Ruby Discussion forum.
                          • Wo3DanW
                            Wo3Dan
                            Thanks Eric, I'll work out the model and post there.
