    Simple venetian blinds
    17 Posts 9 Posters 3.6k Views 9 Watching
    • Mike LuceyM
      Mike Lucey
      Thanks Remus, a very useful component that will definately be used.
      Cheers,
      Mike
        Jim
        Very nice, thanks.
        One challenge I would offer is to get the file size down by trying a lower resolution string (use fewer segments on the circle for the string component.)
          remus
          glad they might be of use to someone.
          On the subject of the file size, i didnt really think about it to be honest. as i dont usually work with large models it isnt usually an issue. i'll bear it in mind next time i do something like this though, as it's obviously important if you are doing soemthing big with lots of components etc.
          Oh and nice one dave, i was tryign to think of a way to make the the length more easily adjustable but couldnt think of anything off of the top of my head.
            Remus, for something like this just remember to hide (Shift+Eraser) the edges that would form the seam line. Don't soften them. FWIW, I expect that the file size could be reduced even further without showing much in the model. If you notice, I quareted the sphere that makes up the little "toggle" on the end of the pull cord. Reducing the number of faces used to create that sphere would have helped a lot too.
              dylan
              Thanks guys, a very useful addition.
              http://dmdarchitecture.co.uk/
              • Wo3DanW
                Wo3Dan
                Remus, Dave R,
                Dave R, seamless?
                It was only yesterday (= last year!) that I read about your advice somewhere in another thread about putting components (parts) seamlessly together by also erasing the inner faces.
                Unfortunately now I can’t find it anymore.
                Something you forgot to do here. But still, your credit. Nice useful component approach, also to Remus, thanks.
                  Very nice blinds Remus. I think those will come in handy.
                  I couldn't help myself. Had to see what I could do to reduce the file size a bit. I could reduce it more but this was quick. I did remove the wood grain texture figuring the user can add that later in their project if desired. I didn't change the pull cord but did modify the others. I also added a center section without cords that can be easily adjusted for length to make the blinds fit as needed.
                  blinds.skp
                    @wo3dan said:
                    Remus, Dave R,
                    Dave R, seamless?
                    Whatchoo talkin' 'bout, Willis? 😄
                    Yeah, I did neglect to delete those faces as I should have done. I was fending off a 3 year old while I was working. I fixed it though.
                    • GaieusG
                      Oh, come on guys, everybody (should) know that trick:
                      http://www.sketchucation.com/forums/scf/viewtopic.php?f=20&t=796
                      (OK - we all know that it cannot be repeated as many times as needed)
                      • Wo3DanW
                        Wo3Dan
                        @gaieus said:
                        Oh, come on guys, everybody (should) know that trick:.......
                        Gaieus, somewhere around Nov 18 some people didn’t seem to know ‘this trick’ and I bet you that his three year old still does not know. But not for long. 💚
                        You see, both of them are putting a perfect component together. This could be applied to similar components since SU does not handle parametric components.
                        And I know, it was just a minor thing to mention. So please forgive me this time, please!!! 😢
                        cheers, Wo3Dan
                          @wo3dan said:
                          Gaieus, somewhere around Nov 18 some people didn’t seem to know ‘this trick’ and I bet you that his three year old still does not know. But not for long. 💚 [/qoute]
                          You're not kidding! That kid is already using one of the PCs aas well as the iMac. He will be using SketchUp before too long. 😲 😉
                          cheers, Wo3Dan
                          No need, nothing to forgive. Your point was well taken. It should be a well known thing and I should not have omitted it. No worries.
                          Dave
                          • GaieusG
                            I was just joking, men, and adding a link there that way. I hope no-one misunderstood me.
                            • Wo3DanW
                              Wo3Dan
                              @dave r said:
                              No need, nothing to forgive. Your point was well taken. It should be a well known thing and I should not have omitted it. No worries...
                              Dave R, Gaieus,
                              No misunderstanding at this side, pure irony, so sorry for asking forgiveness 😲
                              btw, where do I put a request for a ruby plug-inn 💭 that might be useful to some/many?
                              In Ruby-discussions maybe? It will most likely be a very simple ruby (and this is no joke).
                              My request will come with a simple model to show the workaround so fare.
                              cheers,
                              Wo3Dan
                              • boofredlayB
                                boofredlay
                                You have it right, place your request for a ruby in the Ruby Discussion forum.
                                • Wo3DanW
                                  Wo3Dan
                                  Thanks Eric, I'll work out the model and post there.
