    Maximum Render Size?
    32 Posts 16 Posters 8.3k Views 16 Watching
    • kenK Offline
      ken
      On my machine, I can not render above 4000 pixels width without the dreaded "file failed to save". My solution was to turn off the Anti-alias, than I could render above the 4000 limit.
      So make sure that you don’t have the Anti-alias option checked.
        Mr S
        Hi Guys,
        I am trying to avoid any jaggies, so switching off anti-alias is not going to help.
        I am actually trying to use a demo version of Vray which seems to be able to render out bigger files because it gives you the option to write the image to disk when saving.
        I will end up with a totally different "look" from my SketchUp render though!
        Not really much of a solution.
        Mr S
          Charlie__V
          Mr S,
          Some more Info on this Here
          http://www.sketchucation.com/forums/scf/viewtopic.php?f=11&t=195&hilit=search+failed+to+save
          Charlie
            pmiller
            I have never had any problems with exporting very large images (in excess of 8000 pixels) on any computers (over 8 different kinds) with SU except for a machine with only 256 Mb Ram (which just took longer -- paging memory), provided AA is turned off in SU.
            If you export twice as large as you need with anti-alias off, then reduce by half in pshop with bicubic resampling you will get the results you need, and the AA will be much better (not to mention almost instantaneous).
            Just did a test with 8000 pixel image -- export took about 8 seconds in SU (6.4.112). File size was 8.9 Mb, reduced to 3.6 Mb after resampling. I always export JPG with highest quality setting in the SU export dialogue options.
            Can you give some more info on your computer?
              Mr S
              Hi Charlie__V
              Yes, I remember that thread.
              But no successful conclusion was ever reached.
              Google do not seem to have even recognised this as a problem.
              Or they have and just aren't saying anything.
              So, for the time being, large file renders are not really an option.
              Fix for Version 7.0 hopefully?
                Mr S
                Hi pmiller,
                Well, this is very strange.
                I have just tried rendering with anti-aliasing switched off and it made no difference.
                Still getting the 'file failed to save' error.
                Below are my machine specs:
                Dell Precision 390
                WinXP Pro SP2
                Intel Core 2 6600 @ 2.40GHz
                4 Gig Ram
                Nvidia Quadro FX 3450/4000 SDI (Driver Version: 6.14.11.6375)
                Any further ideas?
                Mr S
                  Charlie__V
                  Mr S,
                  I too am curious about Google being quiet on this.
                  For the heck of it, can you try rendering your model with the sky & Ground OFF.
                  I was able to get much higher pix without them.
                  I know it is a workaround, but possibly rendering the model seperate from sky & ground....then re-marry the two in photoshop.
                  Charlie
                    Mr S
                    Sky, Ground and anti-alias all switched off.
                    Still get the error. Grrr!!
                      toxicvoxel
                      I too can confirm that I frequently get this error with or without AA.
                      Model complexity & size has something to do with it. Typically things start to go wrong in the 4500-5000px wide range(aa-off) 6000-700 (aa-on).
                      This has happened on two machines including the latest (2.3GH dualcore/ quadro fx 1600 /2 GB RAM) machine.
                        glenn
                        I too have this problem usualy around 8000px.
                        Seems to be a version 6 (and all it's updates) problem?
                        Appears to me that Google is ignoring the problem?
                        Glenn
                        SU 64112
                        2mg ram
                        DC 2.8
                        XP
                          pmiller
                          @mr s said:
                          Hi pmiller,
                          Any further ideas?
                          Mr S
                          Hmmm - wish I could help. Just tried it again with a model with 600K faces, 125K edges, 10,000 components at 9000 pixels, shadows, textures. No problems.
                          6.4.112
                          XPSP2
                          Dual Core 3.4 Ghz
                          2 Gb RAM
                          Quadro FX 1500
                          Are you exporting jpg highest quality or some other raster format? Are you using one of the newer styles with sketchy edges?
                            Charlie__V
                            Anyone care to try this (attached) file and share your results.
                            My Results:
                            AA off,export to .jpg.......I max out at 6500 pix. wide
                            AA off, export to .tif......I max out at 1800 pix. wide
                            best,
                            Charlie
                            RENDER TEST FILE.skp
                              pmiller
                              9000 pixels to jpg highest quality - no problems. Also same 9000 to png.
                                richcat
                                I tried this out of interest.
                                I very very rarely use this as nearly all my work is rendered.
                                Results
                                AA off,export highest quality to .jpg.......I max out at 9770 pix. wide. The max I have ever used is 3000
                                AA off, export to .tif......I max out at 2140 pix. wide.
                                Richcat
                                  sorgesu
                                  Before V5 I was exporting PNg & Epix at 9999 without any problems. Since V5 I have had problems saving such large files. I tried this particular file with the follwoing results>
                                  AA OFF JPG 9999 OKAY
                                  AA OFF PNG 9999 OKAY
                                  AA OFF EPIX 9999 OKAY
                                  AA ON JPG 9999 RUNTIME ERROR
                                  Triead again and got Runtime Error Again.
                                  I think the complexity of the model has something to do with it as well. This is fairly simple and is not saving as a very large file. I beleive with a very large complex structure I would be less likely to save at 9999
                                  Susan Sorger
                                  Former Seller Hand Rendered Entourage
                                  Former Canadian Authorized Training Centre, SketchUp
                                  • tinanneT Offline
                                    tinanne
                                    I also have this problem, but have found that this is not an issue if upscaling in PS.
                                    I always export to .png @ 3000px with AA on. Then in PS I upscale dpi to 300, which is the lowest a printer would want anyway (SU defaults to 72dpi, if I'm not mistaken). This should be fine for what you need and most likely will need to be downsized.
                                    Executive Director : American Society of Architectural Illustrators
                                    AIP 30 Competition opens soon. ASAI.org
                                    Architectural Rendering
                                      glenn
                                      Looks like I'm going to have to retract my earlier post.
                                      The test render file exported to jpeg at 9000p with aa off.
                                      I tried a recent model, 12meg, also went fine at 9000p aa off.
                                      Glenn
                                      SU 64112
                                      DC 2.8
                                      2mg
                                      nvidia geforce 6200se tc 256mg
                                      xp
                                        Mr S
                                        Just tried rendering the Charlie_V test file.
                                        The best I could get was 7000px with AA switched off.
                                        I loaded up my original file which is a lot more complicated and was only able to get 4000px wide (also, I have shadows disabled). So, there does seem to be a number of factors at work here.
                                        However, it seems stange that we are getting a variety of results from different people with machine specs similar to each other.
                                        I rendered JPEG images using Vray and had no problem producing large files.
                                        But as mentioned previously, Vray can write the image to disk rather than hold everything in RAM.
                                        Any other thoughts?
                                        Mr S
                                        • AnssiA Offline
                                          Anssi
                                          I wonder if maybe the working environment has something to do with the export results too. At work, in a networked environment, I get different results than at home. Writing big images to a network folder often fails, or I get corrupt files, and exporting to the desktop works better. These problems happen only with rel. 6, not with v.4. Version 4 and older only have the AA issue, maxing at about 3000 pixels wide with AA on.
                                          Anssi
                                          • Jean LemireJ Offline
                                            Jean Lemire
                                            Hi Mr S, hi folks.
                                            For a JPG export with anti aliasing off, I can go as far as 7493 horizontal pixels (6636 vertical) with Windows XP-Pro on Pentium 4, 2.6 GHz, 2 Gigs RAM.
                                            I will try on my Mac at home to get a comparison.
                                            Just ideas.
