    Greeble plugin for Sketchup?
    36 Posts 14 Posters 15.4k Views 14 Watching
      Jim
      @stuckon3d said:
      Hi guys,
      new kid on the block here.
      I included a little image i'm working on and having a script like that you have made my life so much easier than modeling each of my tile floors one by one. 😒
      PS: you guys rock, thank you so much for your help and contributions. 😄
      Holy cheese puffs, is that image pure SketchUp? It's fantastic.
      • N
        not registered yet
        The modeling is 100% SU and the render was done in Podium, however I'm still in the modeling stage, I have not even started with the texturing and lighting yet. This is just a press the "render" button render in Podium, all I did is change the time of day. 😄 If you want to see the progress of this image here is the link where im posting them.
        Unknown Forum
        (www.websitetoolbox.com)
        Anyhow, sorry guys did not mean to deviate from the main subject. So... yeah, having a plugin that could do tiling like the floors I modeled would have saved me hours of work, because its not just that you have to draw the lines of the tiles on a plane, but you have to create randomness, then an offset for each tile and them extrude the inside of the offset at various random heights (that was the easy part thanks to "tigs" script (thanks man). So let me tell ya, that was a lot of button pushing. 😛
        [stuckon3d]
        • K
          kwistenbiebel
          Hi Stuckon3d,
          Good to see you on this forum as well man 😄
          I believe you just proofed that this kind of greeble concept can be very useful to Sketchup.
            Jim
            I am making progress, although slow...
            Download the model
            http://www.sketchucation.com/forums/scf/sas/Ruby/download.jpg
            • KrisidiousK
              Krisidious
              you know this script is going to be awesome for stone work...
              it's looking great.
              By: Kristoff Rand
              • jujuJ
                juju
                I can't wait to see this, thx Jim.
                  AcesHigh
                  any update?
                  [AcesHigh]
                    Jim
                    @aceshigh said:
                    any update?
                    I haven't touched it, unfortunately. I wish I could be more definitive as far as a time-frame. Give me a few days to clean up and release what I have.
                      AcesHigh
                      good luck!
                      [AcesHigh]
                      • jujuJ
                        juju
                        Still can't wait to see this Jim...
                          Jim
                          I posted an early plugin for protuding faces. It's not a full-featured greeble plugin; but it does protruding of faces with (optional and user-settable) offsetting, and tapering.
                          See the blog.
                          • KrisidiousK
                            Krisidious
                            do you think I could use this for my 3D hatch Jim?
                            By: Kristoff Rand
                              Jim
                              I think so. Here's an example using a section of your 3d hatch wall
                              404 Not Found
                              (www.sketchucation.com)
                              http://www.sketchucation.com/forums/scf/sas/Ruby/3dhatchdemo.jpg
                                AcesHigh
                                Ok, but do I manually have to create these complicated patterns? With the line tool?
                                This 3d hatch pattern (just the lines, not after gone 3d with the protude tool), looks quite complicated to draw.
                                Worst is that globe mode... how was that 2d pattern created around the globe, so it could be protuded????
                                [AcesHigh]
                                  Jim
                                  Hi Aces,
                                  I'm sorry to say you still need to make your own model. 😄 Kidding aside, I'm sure it is possible to make the pattern automatically, but I have no plans to work on it as of today.
                                  For the sphere, the faces are created naturally when a sphere is drawn in Sketchup. Turn on View/Hidden Edges to see them. Nothing more needs to be done to protrude a sphere over a 2d subdivided plane. Just select the faces and protrude them. The script will treat each face separately in case of hidden edges.
                                    Daniel S
                                    Using ContourMaker.rb (TIG) and protrude.rb you can get great results.
                                    It will be fantastic if countourmaker could make random contours and select the orientation of the countours (x-y-z, like slicer.rb) so you don´t have to rotate the model.
                                    Here i put how i make subdivision to protrude with ContourMaker.rb.
                                    http://sketchup-pro-groups.googlegroups.com/web/protrude+tutorial1.pdf
                                    or the same file here:
                                    http://rapidshare.com/files/64823450/protrude_tutorial1.pdf
                                    Daniel S
                                    http://www.sketchucation.com/forums/scf/sas/Ruby/protrude1 test.JPG
                                      AcesHigh
                                      w00t? I have to create the model myself? So, does that means that plugin that creates award-winning architecture automatically will never be released? 😄
                                      Jim, small models like those are actualy easy to do of course. But these complicated patterns may be impossible on large scale, like an entire cobble stone street. Or even just an entire wall (if the patterns are small).
                                      I wonder if there isnt ALREADY a plugin to create such patterns in 2d. Or if you are not interested in working in one, separately.
                                      If not, do you have a TIP on how to create patterns on big surfaces? Or worst... Ive been using the word pattern... but actually the pattern may not even repeat itself across the entire surface.
                                      ps: wow, it seems Daniel already given a tip about how to do it! Thanks Daniel!
                                      Daniel, if we could find the author of contourmaker, maybe he would agree to try to make it create randon contours. Or maybe someone here could modify contourmaker plugin.
                                      [AcesHigh]
                                      • N
                                        not registered yet
                                        Jim,
                                        The greeble script your working on sounds like it might be right for the task I am trying to do, but on a smaller/simpler scale. I have created many outlines of buildings using the line tool (100+ buildings). I now want to select ALL of them and push\pull them to 12feet. Is there a way to do that in Sketch up?
                                        Many Thanks,
                                        [soccer]
                                          Jim
                                          soccer,
                                          I thought there already was a plugin to push/pull multiple faces. I saw your question on the Google Groups, maybe start a new thread asking your question in the Newbie or Ruby Forum.
                                          Jim,
                                          Many Thanks,
                                          • FletchF
                                            Fletch
                                            Soccer,
                                            you will find that tool on Didier Bur's ruby website... I picked it up there a few weeks ago and love it.
                                            Jim,
                                            This script of your is very powerful already! I love it!
                                            When I combine it with the auto-division power of the Soap Skin Bubble script, it's really awesome.
                                            Here's my post at the KT forum with 3 completely different renders/uses for your script.
                                            Thanks for your work on this.
                                            2 small things to implement would be
                                            1 -that it would automatically divide a chosen face(s) either with a grid or randomly
                                            2 - that it would do secondary or tertiary offsets and pushpulls
                                            But it is already very powerful... thanks for your hard work!
                                            Fletch
                                            • 2 / 2
