    [Tutorial] How to Model Tapered Columns or Cylinders
    3 Posts 3 Posters 6.1k Views 3 Watching
    • H
      Howard leslie
      See attached Tutorial files
      Method 1 - Using Entity Info Dialog Box.
      Method 2 - Using Autofold
      Produced in response to this question on Newbie Forum
      http://www.sketchucation.com/forums/scf/viewtopic.php?f=79&t=3429&p=16898#p16898
      Regards
      Howard L'
      Tapered_Columns_or_Cylinders.skp
      Tapered_Columns_or_Cylinders Method 2.skp
      • GaieusG
        Nice Howard - see I keep explaining and then I forget the simpler method...
        Never mind, learning to use the scale tool is also useful... πŸ˜’
          To use simple scaling to taper something like a column, you can pushpull a cylinder as in the first example tut, then select the top circle, scale it by pulling a corner handle WHILE you are holding down the Ctrl-key, this is so the centre-point becomes the scaling origin, then pull it in a little inwards, THEN type 0.5 in the VCB to make the original 800mm into 400mm [OR type 400mm - note units suffix]...
          The two tuts below and this scaling way are all pretty easy and straightforward...
