    Mac OS X Leopard and SU - text tool problem
    16 Posts 7 Posters 6.0k Views 7 Watching
    • mariochaM
      mariocha
      @mcn said:
      will only allow the default font (which seems to be Tahoma).
      Same problem here. Mac OS 10.5.1
      %(#008000)[Mario C.
        Mark Leichliter
        I get this same behavior. It looks like SU uses a custom font dialog for this - not sure why they don't use the system default. I tried changing fonts using two methods: by just selecting the text, pressing Command-T for the font selection dialog, and making changes therein - nothing happens. Second method was using the model info window and utilizing the "select all screen text" and "update selected text" buttons - again with no effect.
          davekn
          Same problem here.
          2.1GHz IMac
          Mac OS 10.5.1
          Sketchup 6.0 (6.0.1145)
          • T
            tim
            Weird; on my macbook I can do filled text ok but I do have the non-responsive font dialogue. except that I can type a font size value in the top-right field.
            • mariochaM
              mariocha
              and move the slider also.
              But still cannot change font indeed.
              %(#008000)[Mario C.
                Mark Leichliter
                Found this in my console (in case it helps):
                11/26/07 9:03:34 AM SketchUp[2393] *** -[SkpFontPanel tableView:shouldSelectRow:]: unrecognized selector sent to instance 0x2223c00
                  MCN
                  Thank you, Brad. I'm glad to know it's being worked on.
                  Matthew.
                  • GaieusG
                    Thanks Brad for the reply!
                    • bradB
                      brad
                      Hi Everyone,
                      Sorry for the late response on this topic.
                      The Font problem is a known issue with Leopard using the 3D Text Tool.
                      Here are a couple of other gotchas...All the problems are being worked on as I type and we hope to have this problems resolved soon.
                      Error 404 (Not Found)!!1
                      (sketchupdate.blogspot.com)
                      Hope this helps.
                      Brad
                      Google SketchUp QA
                      Brad
                      SketchUp QA
                      • mariochaM
                        mariocha
                        Brad
                        Google SketchUp QA
                        It is not only 3D Text Tool, it is ALL Text tolls !!!
                        Hum... I hate a response which is off the matter. Feels like a quick "get it off my desk".
                        %(#008000)[Mario C.
                        • GaieusG
                          Hi Guys,
                          Though I'm on Windows, I know that most recent maintenance release 4 covered some issues with Leopard.
                          Could you download and install and check back whether the problem still exists?
                          • mariochaM
                            mariocha
                            Hey !!! After reading your message, I launched SU and, bing, it says a newer version is available.
                            And, YES ! the text problem is solved ! Mac v.6.0 (6.4.120)
                            Great Job guys !
                            %(#008000)[Mario C.
                            • GaieusG
                              Ah, good news then.
                              Thanks for reporting back (they need reassurance at the very moment...)
                              πŸ˜’
                              • T
                                tim
                                Hmm, I have that same version and although I can set the font and size of 3D text I can't do anything with dimensional or other text; the font dialogue is simply ignored and attempting to use the context menu and the font->styles option just makes a chirp.
