Roof.rb v1
TIG, the latest version seems to work alot better, only problem I'm having is with the gable roofs, they all seem to come up a little short. Keep up the good work. Thanks again for a great script.
Mike
http://www.sketchucation.com/forums/scf/sas/Ruby/errors4.jpg
TIG, v1.2 is working flawlessly on my work computer.
Thanks. -
I did have the same problem as Alpro posted above with the gable roof stopping short. This was intermittent though.
Hi TIG
Very nice work ! V1.2 is working OK here, both on W2000 and XP.
It's a pity that I can't translate it to french (script is crypted)
Regards, -
@didier bur said:
Hi TIG
Regards,Since I've copied your cunning techniques you should be able to crack it easily! ?;^)
Please feel free to make a re-encrypted french version, with a suitable change to the header in which you take the blame for the translation! ?:-| Toit.rb ?
You could also rework RoofHelp.mht into french - as say ToitAide.mht with the end menu bits reworked to suit, before recrypting...Wait for v1.3 to arrive before doing any translating. The fix for v1.2 itself caused a glitch with the materials for some types of gables that I didn't spot before reissuing it yesterday...
Version v1.3 of Roof.rb is now available.
Click here: http://www.sketchucation.com/forums/scf/viewtopic.php?f=153&t=1516
It fixes most of the outstanding bug reports. But keep the feedback coming... -
TIG, v1.3 is working perfectly, thanks for a great script,it should be a big time saver.
Mike
The roof script is amazing Tig. It worked as advertised with no hitches. As an architectural illustrator it will get used to death. Your efforts are deeply appreciated,
Thank you!!!Robert
V1.3 now offsets a gable roof to the side of the polygon used to define the roof.
Sorry
Seasdes
http://www.sketchucation.com/forums/scf/sas/Ruby/070829-1134.jpg
Sorry
SeasdesA new one - I haven't managed to reproduce that (yet). As you can see from others comments they aren't getting the problem. Does it always do it, or at certain rotations of the rectangle about the origin? What are the setting you use in the dialog and system are you on ?
Edit: Found out the cause - looking for a fix. IF you have a manually drawn rectangle - 4 sides, drawn clockwise and the face reversed (down) you get your problem; with the same face if you reverse (up) it before running gable-roof tool the two gable-ends swap over but otherwise the roof is in the right place. Must be trappable and fixable - thinking on it...
Looking into it now. It shall be fixed... -
Thank you TIG. This is a truly wonderful script that will save me a lot of time
Seasdes -
@tig said:
Sorry
Edit: Found out the cause - looking for a fix. IF you have amanually drawn rectangle - 4 sides, drawn clockwise and the face reversed (down) you get your problem; with the same face if you reverse (up) it before running gable-roof tool the two gable-ends swap over but otherwise the roof is in the right place. Must be trappable and fixable - thinking on it...
Looking into it now. It shall be fixed...Hello TIG
The problem that I reported happens all of the time - regardless of how the rectangle is drawn. The problem did not occur in V1
Seasdes
Tig
Still having the same problems with v3 as with the previous versions.
The get slope angle works fine & so the script must be working - but as previously said I don't even get the initial info box when trying to draw any of the roofs.
This must be a Mac thing.Dave
@davekn said:
Tig
Are you getting any messages in the Ruby Console Window when you try and run it ?
Are there any other Mac users out there trying this ? Successfully or not ? I don't know of any Mac/PC issues that could be causing this... -
Super and very much needed script but the Gable still is iffy for me and some faces that are created square are refused by the script and will not execute.
Here is a jpg and skp for your review.Dave
Tig
The following comments are in the Ruby console
Hipped Roof -
Error: #<NoMethodError: undefined methoddialog_hip' for Roof:Class> (eval):210:inhip'
(eval):2749
(eval):210:in `call'
(eval):210Mansard Roof -
Error: #<NoMethodError: undefined methoddialog_man' for Roof:Class> (eval):802:inmansard'
(eval):2750
(eval):210Gable roof -
Error: #<NoMethodError: undefined methoddialog_gable' for Roof:Class> (eval):1514:ingable'
(eval):2751
(eval):802:in `call'
(eval):802Pyramid roof -
I still get the instruction to pick a rectangular face & edge etcDave
fantastic script TIG!
Please allow me to make the following small observation:
see attachment
Hello,
The problem could be solve making one of the wings a block.
DaveThis error seems to be because the face although seemingly a rectangle has 5 sides ? I'm working on a fix for some other gable related problems and will try to fix this then. In the meanwhile draw a line on the gable edge, group it and edit the group and then draw a rectangle over the original, gable roof the lot new face in the group. Explode the group and you should still have the gable roof group. A fix is in progress...
@davekn said:
Tig
Hipped Roof -
(eval):2749
(eval):2750
(eval):2751
Mac must call sub def's differently from PC. I'll look into redoing these sub-def dialogs...
