    Roof.rb v1
    80 Posts 20 Posters 13.2k Views 20 Watching
      davekn
      Tig
      The following comments are in the Ruby console
      Hipped Roof -
      Error: #<NoMethodError: undefined method dialog_hip' for Roof:Class> (eval):210:in hip'
      (eval):2749
      (eval):210:in `call'
      (eval):210
      Mansard Roof -
      Error: #<NoMethodError: undefined method dialog_man' for Roof:Class> (eval):802:in mansard'
      (eval):2750
      (eval):210
      Gable roof -
      Error: #<NoMethodError: undefined method dialog_gable' for Roof:Class> (eval):1514:in gable'
      (eval):2751
      (eval):802:in `call'
      (eval):802
      Pyramid roof -
      I still get the instruction to pick a rectangular face & edge etc
      Dave
        tomot
        fantastic script TIG!
        Please allow me to make the following small observation:
        see attachment
        http://www.sketchucation.com/forums/scf/sas/Ruby/roof.jpg
        my plugins
        tomot
        • I Offline
          Iglesias
          Hello,
          The problem could be solve making one of the wings a block.
          301 Moved Permanently
          (www.sketchucation.com)
            @dtrarch said:
            Super and very much needed script but the Gable still is iffy for me and some faces that are created square are refused by the script and will not execute.
            Dave
            This error seems to be because the face although seemingly a rectangle has 5 sides ? I'm working on a fix for some other gable related problems and will try to fix this then. In the meanwhile draw a line on the gable edge, group it and edit the group and then draw a rectangle over the original, gable roof the lot new face in the group. Explode the group and you should still have the gable roof group. A fix is in progress...
              @davekn said:
              Tig
              Hipped Roof -
              (eval):2749
              (eval):210
              Mansard Roof -
              (eval):2750
              (eval):210
              Gable roof -
              (eval):2751
              (eval):802
              Pyramid roof -
              Dave
              Mac must call sub def's differently from PC. I'll look into redoing these sub-def dialogs...
                @iglesias said:
                Hello,
                You got there ahead of me ! However, we do need a kinder gable-roof rectangle checking routine - I'm on to it...
                  see attachment
                  The roof that is created is a 'true' hip with all of the faces at the same angle/slope. If you want a single springing point for all the apse rafters then make the apse-end a semi-circle, OR be prepared to make an uneven pitched roof by hand...
                    The good news is... I have had a 'Pauline Moment' [road to Damascus and all that...]. I have seen the light... I am setting off re-writing the gable (and pyramid) tools so that you will only need to select point-one then point-two that will define where the line for where the gable (or pyramid pitch) starts and then point-three which gives the 'depth' of the gable-roof's base (or the pyramid's other side) - the point will be translated to a common 'z' anyway, so its exact location isn't critical, however, best to keep it square to the first two points as it'll return the true perpendicular distance from line pt1-pt2 to pt-3 anyway.
                    The bad news is... you'll have to live with the deficiencies of v1.3 a bit longer while I fix all of this in "v2.0" with a new help .mht file...
                    It'll take 'a few days'...
                      dylan
                      That sounds good TIG and an improvement on what is already a fantastic tool.
                      Look forward to testing version 2.0!
                      http://dmdarchitecture.co.uk/
                      • kmeadK Offline
                        kmead
                        This looks like yet another great script. I unfortunately echo Davekn's experience on a PPC Mac. I will try this next week on my work Intel Mac to see if the issues are the same. As an aside the .MHP file doesn't open on my Mac. The PDF is fine however.
                        Many thanks and have a great day.
                        Karl Mead
                        I created Dilbertville, sorry about that...
                          Version 2 now out see this thread instead...
                          • jujuJ Offline
                            juju
                            I'm closing this thread seeing that TIG has version 2 out already. You can find the thread here should you wish to continue posting about the Roof.rb script.
                            Thx.
                              tomislavm
                              Thank You for this, it is very useful.
                                Jim
                                There's version 3 here.
                                • 4 / 4
