    Roof.rb v1
    80 Posts 20 Posters 18.1k Views 20 Watching
      seasdes
      Thank you TIG. This is a truly wonderful script that will save me a lot of time
      Seasdes
      Using Sketchup Pro 2019
        seasdes
        @tig said:
        @seasdes said:
        V1.3 now offsets a gable roof to the side of the polygon used to define the roof.
        Sorry
        Seasdes
        A new one - I haven't managed to reproduce that (yet). As you can see from others comments they aren't getting the problem. Does it always do it, or at certain rotations of the rectangle about the origin? What are the setting you use in the dialog and system are you on ?
        Edit: Found out the cause - looking for a fix. IF you have amanually drawn rectangle - 4 sides, drawn clockwise and the face reversed (down) you get your problem; with the same face if you reverse (up) it before running gable-roof tool the two gable-ends swap over but otherwise the roof is in the right place. Must be trappable and fixable - thinking on it...
        Looking into it now. It shall be fixed...
        Hello TIG
        The problem that I reported happens all of the time - regardless of how the rectangle is drawn. The problem did not occur in V1
        Seasdes
          davekn
          Tig
          Still having the same problems with v3 as with the previous versions.
          The get slope angle works fine & so the script must be working - but as previously said I don't even get the initial info box when trying to draw any of the roofs.
          This must be a Mac thing.
          Dave
            @davekn said:
            Tig
            Dave
            Are you getting any messages in the Ruby Console Window when you try and run it ?
            Are there any other Mac users out there trying this ? Successfully or not ? I don't know of any Mac/PC issues that could be causing this...
              dtrarch
              Super and very much needed script but the Gable still is iffy for me and some faces that are created square are refused by the script and will not execute.
              Here is a jpg and skp for your review.
              Dave
              404 Not Found
              (www.sketchucation.com)
                davekn
                Tig
                The following comments are in the Ruby console
                Hipped Roof -
                Error: #<NoMethodError: undefined method dialog_hip' for Roof:Class> (eval):210:in hip'
                (eval):2749
                (eval):210:in `call'
                (eval):210
                Mansard Roof -
                Error: #<NoMethodError: undefined method dialog_man' for Roof:Class> (eval):802:in mansard'
                (eval):2750
                (eval):210
                Gable roof -
                Error: #<NoMethodError: undefined method dialog_gable' for Roof:Class> (eval):1514:in gable'
                (eval):2751
                (eval):802:in `call'
                (eval):802
                Pyramid roof -
                I still get the instruction to pick a rectangular face & edge etc
                Dave
                • T
                  tomot
                  fantastic script TIG!
                  Please allow me to make the following small observation:
                  see attachment
                  http://www.sketchucation.com/forums/scf/sas/Ruby/roof.jpg
                  my plugins
                  tomot
                  • I
                    Iglesias
                    Hello,
                    The problem could be solve making one of the wings a block.
                    404 Not Found
                      Dave
                      This error seems to be because the face although seemingly a rectangle has 5 sides ? I'm working on a fix for some other gable related problems and will try to fix this then. In the meanwhile draw a line on the gable edge, group it and edit the group and then draw a rectangle over the original, gable roof the lot new face in the group. Explode the group and you should still have the gable roof group. A fix is in progress...
                        @davekn said:
                        Tig
                        Hipped Roof -
                        (eval):2749
                        (eval):210
                        Mansard Roof -
                        (eval):2750
                        (eval):210
                        Gable roof -
                        (eval):2751
                        (eval):802
                        Pyramid roof -
                        Dave
                        Mac must call sub def's differently from PC. I'll look into redoing these sub-def dialogs...
                          @iglesias said:
                          Hello,
                          You got there ahead of me ! However, we do need a kinder gable-roof rectangle checking routine - I'm on to it...
                            see attachment
                            The roof that is created is a 'true' hip with all of the faces at the same angle/slope. If you want a single springing point for all the apse rafters then make the apse-end a semi-circle, OR be prepared to make an uneven pitched roof by hand...
                              The good news is... I have had a 'Pauline Moment' [road to Damascus and all that...]. I have seen the light... I am setting off re-writing the gable (and pyramid) tools so that you will only need to select point-one then point-two that will define where the line for where the gable (or pyramid pitch) starts and then point-three which gives the 'depth' of the gable-roof's base (or the pyramid's other side) - the point will be translated to a common 'z' anyway, so its exact location isn't critical, however, best to keep it square to the first two points as it'll return the true perpendicular distance from line pt1-pt2 to pt-3 anyway.
                              The bad news is... you'll have to live with the deficiencies of v1.3 a bit longer while I fix all of this in "v2.0" with a new help .mht file...
                              It'll take 'a few days'...
                                dylan
                                That sounds good TIG and an improvement on what is already a fantastic tool.
                                Look forward to testing version 2.0!
                                http://dmdarchitecture.co.uk/
                                • kmeadK
                                  kmead
                                  This looks like yet another great script. I unfortunately echo Davekn's experience on a PPC Mac. I will try this next week on my work Intel Mac to see if the issues are the same. As an aside the .MHP file doesn't open on my Mac. The PDF is fine however.
                                  Many thanks and have a great day.
                                  Karl Mead
                                  I created Dilbertville, sorry about that...
                                    Version 2 now out see this thread instead...
                                    404 Not Found
                                    • jujuJ
                                      juju
                                      I'm closing this thread seeing that TIG has version 2 out already. You can find the thread here should you wish to continue posting about the Roof.rb script.
                                      Thx.
                                      • T
                                        tomislavm
                                        Thank You for this, it is very useful.
                                          Jim
                                          There's version 3 here.
                                          404 Not Found
                                          • 4 / 4
